S-550 2015-2023 Cold air intake Discussion Recommendations
Curious what’s a good option for cold air intake for A 2017 gt 5.0 convertible. Was looking at afe. Just a good all around system. And washable filter is a plus.
Roush makes a good one, air aid is pretty good. I believe most if not all the Cai's filters are washable nowadays. It really depends on what you are looking for also. Some you can get with nice plexi glass so you can see in it with out it being open on top or you could go old school and leave it open (it's the cheapest way lol) you can go metal tubing but then heat becomes a factor. What I am saying is it's really personal preference everyone has their favorite. I have two mustang's they are older than yours (08,07) and one has a Roush and the other has a air aid both perform well and washable filters and I am satisfied by both.
Received 1,529 Likes
You can narrow it down a bit by thinking about why you are considering this and what you want out of it.
If you are hoping for significant performance gains, you might want to check into that a bit first, so you won't be disappointed. The factory intakes are really good these days, not a lot of room for improvement. You have a true Cold Air Intake from the factory, so that's not an improvement to be had with an aftermarket intake.
Also consider whether you want a tune -- most aftermarket intakes require a tune, which can void your warranty in some situations and depending on how the dealer manages it. And there is the added cost of a tuner device.
If you want an intake for looks; then pick one that you like the looks of.
I have a 2019 GT convertible auto & I run the open-element with the tune - night & day difference over stock https://www.steeda.com/steeda-555-39...power-pack-bdx
We also have the closed box ... but here is a nice video explaining the differences:
Let me know if I can help answer any questions at tim@steeda.com
TJ
TJ
Johnnyg65 (5/25/21)
CAÍ w/o a tune worth it?
I have a 2018 ecoboost and need to add more hours power and was researching CAÍ, Blow off valve and mod exhaust. Based on what I’m seeing, there’s little benefit of an after market CAÍ without the Tune, which is what you hinted to here. Besides I don’t want to void my extended warranty. What’s your take or recommendation on the blow off valve, and what exhaust do u recommend for a mid level sound (don’t want anything too loud) that will increase power? Thanks in advance for your time.
I don't know the specifics for turbocharged engines; but I'm pretty sure that other modifications like changing the blow-off valve will void the warranty also (because it can potentially over-stress the engine) . . . you might get better response if you start a new thread with a clear subject line specific to your questions
11/2/17 09:34 AM
