Sponsored by:
Sponsored by: CARiD
Morpace Survey shows options and power output of S550
Old Oct 29, 2013 | 08:29 AM
RandyW's Avatar
If you're constantly adjusting your speed, you're eating into your fuel economy. I'm a fan of cruise control when used properly. Besides heeding the warning about using it on ice/frost/snow, a thoughtful driver will still use the accelerator when passing. It does drive me crazy when I'm on a four-lane highway stuck behind two oblivious drivers who are driving side by side at almost the exact same speed, because the passer is too discourteous or lazy to pass and get out of the way.
Old Oct 30, 2013 | 08:35 AM
bob's Avatar
bob
Heh, I use cruise control to see how good my fuel economy can be. Otherwise it pretty much stays off.
Now if Ford introduced an adaptive cruise control that didn't require me constantly fiddling with it as I moved in traffic I might be more inclined to use it.
Old Oct 30, 2013 | 11:26 AM
StangNut's Avatar
No ! The current 5.0 Coyote is a true 302 cubic inch 5.0.. The previous push rod 302's in the fox bodies and SN-95 from 94 and 95 were technically 4.9 liters..
They listed it as a 4.9L because 302 cubic inches is 4.94889 liters. It doesn't matter what motor it is. If the it displaces 302 ci, it's a 4.9L.
Old Oct 31, 2013 | 06:49 AM
Thomas S's Avatar
They had all of the displacements wrong. The 3.7 is listed as a 3.8, the 2.3 as a 2.4 and the 5.0 as a 4.9. I think they used generic numbers as a what if situation. The 2.4 makes more horsepower than the 3.8 so "wouldn't you rather have the smaller more fuel efficient more powerful engine?" They are trying to see how many Mustang owners would accept the more efficient engines moving forward into the new age of government mandated fuel economy standards. I wouldn't lend any credence to any of the numbers listed. That's my take on it anyway.
Old Oct 31, 2013 | 07:54 AM
That's incorrect
The bore is 92.2mm and the stroke is 92.7mm
This works out to a displacement of 4.9513367 liters
Old Oct 31, 2013 | 10:00 AM
StangNut's Avatar
Originally Posted by 2k7gtcs
That's incorrect
So how many cubic inches does that make it?
How many ci's were the other 302's? (60's, fox, etc)
Do you have the bore and displacement of those?
Great info. Thanks for the correction.
Old Oct 31, 2013 | 03:16 PM
RandyW's Avatar
As I recall, the old one was about 301.9 ci and the Coyote is about 302.1. So they both round to 302 ci, but while the old was a tiny bit shy of 4.95, the new one is ever so slightly more than 4.95, which can accurately be rounded up to 5.0.
Old Oct 31, 2013 | 03:35 PM
The old one had a bore of 4" (101.6mm) and a stroke of 3"(76.2mm)
That's comes to 301.5936ci or 4.942L
As you can see completely different bore and stroke but the numbers end up close to the same
Old Nov 2, 2013 | 08:35 AM
bob's Avatar
bob
To bad the Coyote doesn't have a 4" bore, that would be worth another 10 or 15hp just due to all that extra real estate allowing for bigger valves and/or less shrouding.
Diode Dynamics
Jun 12, 2018 03:26 PM
Diode Dynamics
Feb 28, 2018 09:37 AM
Detroit Steel
Sep 21, 2015 03:35 PM
cloud9
GT350
Aug 18, 2015 01:34 PM
MRGTX
Jul 21, 2015 02:08 PM
