Sponsored by:
Sponsored by: CARiD
HVAC "issue"
Old Jan 12, 2015 | 07:54 AM
elfiero's Avatar
HVAC "issue"
The little women asked me to check out her HVAC system yesterday because in the manual mode, set to floor, and temp on high, fan on high, you don't get as much air volume discharged as when it is in the automatic mode. Sure enough, as usual, she's right. I know this is a first world problem(but I'm a first world kinda guy) and I was wondering if anyone else has noticed this or, barring a trip to the stealership, if anyone had any ideas?
Old Jan 12, 2015 | 09:09 AM
wannabe's Avatar
My immediate thought would be to leave it on auto. Especially considering you pay extra for it (package). It doesn't sound 'intuitive', but it's probably operating as designed.
Old Jan 12, 2015 | 11:32 AM
Cobrakev's Avatar
Does she have the recirculates with on? If so this will decrease the flow and where the heat is distributed. Try it with the switch off
Old Jan 12, 2015 | 12:54 PM
elfiero's Avatar
She was talking with recerc off. I tried both ways and it got even worse with recerc on.
Old Jan 16, 2015 | 10:38 AM
FordService's Avatar
I recommend you get this looked at by your Ford Dealer, elfiero. Also, please PM me with your VIN, dealer, mileage, full name, and best daytime number. I’ll get a customer service manager involved.
Deysha
Old Jan 17, 2015 | 10:32 AM
Lime GT's Avatar
Ahh, shades of 2005- early 06 "small amount of airflow to floor when in Floor Mode" in which Ford's answer was "working as designed". In mid 06 Ford redesigned the plenum ducts, check the parts manual. I also believe the HVAC module was reprogrammed as I changed my 05's out with an 07 and airflow is now proper to floor.
Old Jan 17, 2015 | 03:51 PM
elfiero's Avatar
Well, went to the stealership, guess what- "That's absolutely normal, sir!" I too believe it's a air door problem, and most likely is a module programming issue. I did find some of it has to due with the fact that a lot of the air blows on the firewall side of the throttle pedal(not touching your foot)- not doing much good there, is it? Temporarily, I might McGyver a deflector and temporarily attach it so the air will blow on her feet. Because I am a former dealership mechanic and foreman, I know better than to let those guys play around puttering with either of my vehicles. I know they mean well, but at the end of the day- it's not theirs- so why should they care enough to do it perfect?
Old Jan 21, 2015 | 09:40 AM
You’re welcome to get a second opinion at a different Ford Dealer, elfiero. As I mentioned before, I’m happy to escalate this for you if needed.
Deysha
coreyplant
Jun 30, 2015 06:39 AM
SVS
Dec 31, 2014 09:27 AM
cntchds
Dec 22, 2012 06:31 PM
