GENUINE FORD ACCESSORY Keyless Entry Keypad
Has anyone added the keypad to a 2016 Mustang GT with push button start? The instructions say cycle the key 8 times, I don't have a key. Thanks for any help.
Fritz
Updated titile for Searchability!
Kc Admin
Fritz
Kc Admin
I finally got an answer, you cycle the push button starter 7 times and on the 8th you stop at on and your locks will cycle and then you hit lock on the remote keypad and all key fobs and they will then be linked to your car.
I just can't watch this confusion any more.
For clarity:
Ford sells an accessory 5 key keypad that you mount to the car. Said keypad is operable to unlock the car like an alarm fob but is permanently attached to the vehicle and secured with a programmable code.
Ford has been selling the same keypad for several years with cross-vehicle compatibility. In order to get the keypad paired with the keyless entry system in prior vehicles, you would cycle the key on and off several times during the process.
Ford never updated the instructions for cars that don't come with a physical key. So OP wanted to know what to cycle in place of the key in order to pair the keypad with the vehicle. The answer is the start button, presumably without depressing the brake so the car doesn't start.
Sound right OP?
For clarity:
Sound right OP?
Fteich (10/1/16)
I know this post is older but no one ever posted this. The keypad works with probably any Ford car that has a keyfob.
For cars with physical keys in the ignition the instructions are correct, for cars with push to start you just press the button 7x instead (not pushing on the break), ending in on. So 1 time on, 1 time off counts as 1.
https://www.searchfordparts.com/oem-...ad-kb3z14a626a
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
https://www.fordpartsgiant.com/parts...tra2=&filter=()
Applications!
https://accessories.ford.com/keyless...y-remote-start
Still Out There!
KC Admin
Applications!
Still Out There!
KC Admin
