Diode Dynamics S550 Mustang Rear LED Side Markers Are Here!
Diode Dynamics S550 Mustang Rear LED Side Marker Pair (15-16 All ) | SAS-1071 | Free Shipping!
Product Benefits
- Red, clear, and smoked lens options
- Easy plug and play installation, no tools required
- Optical reflector pattern and LED focal strip
- Powerful SMD LEDs with constant-current driver
- Non-polar input, for hassle-free installation
- High reliability with embedded transient voltage suppression
- Ultrasonically welded for OEM longevity
- DOT/SAE compliant output and assembly (red lens)
- 100% Made in USA
*Available in Red, Smoked and Clear*
Convert your rear side marker on you 2015-2016 Mustang with this new Diode Dynamics S550 Mustang Rear LED Side Marker Pair. These new side markers by Diode Dynamics will shine much brighter than your stock OE side markers and give you the added benefit of customizing your lens color. Your stock OE factory rear side marker on your Mustang GT, EcoBoost or V6 uses a single halogen bulb for lighting. This Diode Dynamics S550 side marker replaces the entire factory assembly and incorporates one full LED focal strip that lights up the entire side marker reflector.
Diode Dynamics Rear LED Side Marker uses powerful SMD LEDs with a constant-current driver. These LED side markers are full replacements for you factory side markers and use an embedded transient voltage suppression. Unlike the OE factory side marker that shines in the middle only, this Diode Dynamics LED side marker has a solid LED focal strip that shines brighter and looks much better than your single factory halogen bulb.
Diode Dynamic's S550 Mustang Rear LED Side Marker Pair is made in the USA. The output and assembly on these red side markers for your Mustang are DOT/SAE compliant. They are ultrasonically welded for OE longevity and feature non-polar input for a quick and easy installation. To install these you simply need to pop and unplug your old side markers out and replace them with these Diode Dynamics side markers.
These will be in stock next week, currently taking pre-orders! First come first serve!
Best Regards,
TJ
Product Benefits
- 100% Made in USA
Best Regards,
TJ
Product Benefits
- 100% Made in USA
Best Regards,
TJ
Product Benefits
- 100% Made in USA
Best Regards,
TJ
Hmm - I just opened it.
Can you try with a different browser?
http://www.steeda.com/diode-dynamics...-all-sas-1071/
If you are still having issues, try to get to it manually: Home 2015-2016 Mustang Parts 2015-2016 Mustang Electric 2015-2016 Mustang Tail Lights Diode Dynamics S550 Mustang Rear LED Side Marker Pair (15-16 All)
