Sponsored by:
Sponsored by: CARiD
Barton short throw shifter spring
Old Dec 27, 2017 | 09:32 AM
motor12's Avatar
About a month ago i installed a Barton flat stick short throw shifter in my 2017 GT. Reverse is push down and over/up. I used the stiff spring set up to start with as the mfg. said give it time as the spring tension will change. Well I've gotten used to the stiffer springs and would not want to go to a softer feel. I changed the trans fluid to RP syn. and it feels like a different car. Second to third only requires a positive push, no more guiding the stick to third. This info is for people wondering how the shifter works with the stiff spring set up. I also mounted directly to the trans for a more solid feel.
Old Dec 26, 2019 | 09:45 AM
motor12's Avatar
Just a follow up on the Barton shifter. Since instillation a couple years ago I've racked up about 1000 miles on my 2017 GT, I know that's not much. The shifts are solid and direct, no fishing for gears. Makes driving fun, I would buy this shifter again.
Old Dec 26, 2019 | 10:37 AM
Nemisus's Avatar
Hey Motor12,
While I do not have a 2017, my 2007 has never been more enjoyable to drive since I added the Barton Flat stick. The direct mount to trans is also the only way to go. I did the Blow-Fish Racing mount the same time I installed the Barton.
Cheers and thanks for sharing!
Nemi
shouldhavegottheGT
Mar 4, 2015 07:12 AM
slow.stang
Jul 4, 2014 05:57 PM
timstang
'10-14 Roush Mustangs
Sep 15, 2012 11:16 PM
c6dreamvette
2012-2013 BOSS 302
Jul 7, 2012 09:04 AM
Cavero
14
Mar 25, 2008 09:03 PM
