2015 Mustang Whiteline Transmission Mount Insert Install Video
Former Vendor
Whiteline KDT928 Mustang Transmission Insert V6/GT/Boss 11-15
In this video we demonstrate how to install a Whiteline Transmission Mount Insert on the new 2015 Mustang with a manual transmission. Many have been curious if this insert will fit on the new S550 platform since it still uses the MT82 transmission. We have found that it does, and is as easy to install on the 2015 Mustang as it was on the pervious models. This mount fills the gap in the transmission to make it much stiffer and give you much better feel.
Installation is easy, and once you get your Mustang off the ground should only take you about 10 minutes to install. If you're tired of grinding gears and missing those critical high RPM shifts, this Transmission Mount Insert from Whiteline should be the go to choice for your Mustang.
For more 2015 Mustang parts available at CJ Pony Parts check out:
2015 Mustang Parts & Guide | Free shipping | CJ Pony Parts
