Won’t shift
Won’t shift
Replaced the the clutch with a new one. Got the hole kit slave cylinder master cylinder bearing new line all the good stuff. Whenever i try to shift gears while pressing in the brakes, it like hitting a wall or if i have it in gear and try to take it out i have to yank it out or turn the car off first.
The Analog Admin!
Received 2,983 Likes
Welcome,
What Year Stang?
What Engine?
What Exactly Did You Use To Repair Clutch? Factory Ford or Aftermarket. Can You Supply Part Numbers?
What Exactly Failed on Original Clutch.
Did You Scan For Any DTC Codes??
Kc
What Year Stang?
What Engine?
Kc
M-PACT 07199WS
clutch was getting spongy and car was jerking when taking off from 1st gear
Only codes that are showing is o2
