Rough idle
Old Oct 28, 2014 | 06:10 AM
trackpack13gt's Avatar
Rough idle
I have a 13 gt track pack. When the engine is at optimal operating temperature, when idling the revs are fluctuating between 600-800 rpm. Is this normal or a vacuum leak?
Old Oct 30, 2014 | 10:06 PM
Anyone?
Old Oct 30, 2014 | 11:16 PM
jc46002003's Avatar
is the motor sputtering? Like it's not timed right? Or are the RPMS just changing like there's a control issue?
If sputtering, I don't know. I the RPMS are just changing, then that's a computer issue most likely. Pull the battery cables for a few minutes, re-attach, start-up. See what happens. It's just a basic step you can do on your own. It may or may not help.
Old Oct 30, 2014 | 11:25 PM
How many miles? Some say this happens when throttle body and/or MAF needs cleaning.
You didn't provide much info.
How do you drive it - in traffic all the time, all highway, mix of both? Baby it all the time so it loads up? Or do you take it up to redline on a regular basis and blow the crap out of it?
Old Nov 1, 2014 | 08:47 PM
I will disconnect the battery.
The motor is not sputtering, it is fluctuating rpms.
Its has 36500 miles.
It is driven mixed 50/50 city/hwy.
I am gentle on the car and rarely drive agressively.
Old Nov 5, 2014 | 11:19 AM
I disconnected the battery and it is still slowly fluctuating.
Old Nov 5, 2014 | 12:32 PM
Critical Mass's Avatar
If the fuel filter replaceable? If so, I'd start there and also clean the MAF sensor.
http://www.latemodelrestoration.com/...on-FG1083-S197
It is fluctuating because the computer is constantly having to adjust the air/fuel mixture to keep it running. Which usually means it is constantly not getting enough of one or the other. so it fluctuates as it adjusts.
Old Nov 5, 2014 | 12:59 PM
El Coyote GT/CS's Avatar
I would suspect this ^
Also, look up the throttle position relearn procedure and try that.
Mpaps
Oct 11, 2017 08:06 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
PonyMuscletang13
Sep 26, 2015 02:33 PM
Airborne42
Sep 24, 2015 11:01 AM
