Rotten egg smell during acceleration?
Old Jul 12, 2012 | 03:00 PM
Where does the smell emanate from? Vents? Could it be coming in the sound tube? Do they even still have those?
Old Jul 13, 2012 | 10:14 PM
Shifterboy45's Avatar
Originally Posted by Kinyodas
It would smell much, much worse... I knew a girl had a old Ford Escort - it smelled like waffles coming out the vents - never found out why...
waffles?!! waffles?!! where?
I would put some bacon on the exhaust manifold and drive around for breakfast
Old Jul 13, 2012 | 10:16 PM
i think he said it was a V6 car... dont think they have 'em
Old Jul 20, 2012 | 08:14 AM
Mustang Mafia's Avatar
Originally Posted by dtp03
I have the same issue as the OP, under heavy accel it just smells bad. Warmed up or not it is the same. I haven't tried it with the Traction control turned off to see if it's dragging the brake or something.
I have tried it with the A/C on, off, and with the air turned off completely.
oh and its an 11 GT prem Automatic.
This has been an issue since mile 12(picking it up from the dealer) of owning the car for me, 20k later it is still the same.
Haven't asked the dealer about it since they seem to look at you like you have 3 heads when you bring up dumb things like this to the service dept.
Mine has done it since day one as well. I made a post about it a year ago or so. Car is fine but the smell still happens.
Old Jul 22, 2012 | 09:15 PM
dtp03's Avatar
^ Auto trans or standard?
Old Jul 29, 2012 | 07:43 PM
The bulletproof 6r80
Old Jul 30, 2012 | 08:39 PM
conv_stang's Avatar
since it seems to only be affecting the auto cars. Could be something in the trans, maybe a slight fluid leak under aceleration onto the exhaust?
Old Aug 1, 2012 | 12:03 PM
Moustang's Avatar
Rotten egg smell is almost always the catalytic converter. If you're smelling it inside the car you may have an exhaust leak near the mufflers that's coming into the car through the sound tubes.
Old Aug 1, 2012 | 12:42 PM
Flagstang's Avatar
Spam Connoisseur
I got هَبوب‎ed
I do not see how the sound tube would let smell into the cabin. If they are under throttle the air under the car would be pushing any smell away.
Old Aug 1, 2012 | 01:03 PM
Moustang's Avatar
Air does funny things when running over uneven surfaces. Have you ever had trouble trying to open a door because of a vacuum effect while the wind was blowing past really hard? There may be a pressure differential causing a vacuum effect. Don't forget the purpose of the sound tubes themselves is to capture air pressure waves and direct them inside the car, it can do the same for smells. And like smell, sound waves don't pass through blowing wind well.
But there is another possibility, which is that the smell wasn't coming from his car at all, it was coming from the car in front of him.
Either way, a strong rotten egg/sulfur odor is a catalytic converter. It is the only part of the car that emits hydrogen sulfide.
Old Aug 3, 2012 | 06:42 AM
Rando's Avatar
I'm pretty sure it's the smell of carbon. Growing up I had this problem when I drove my first car in high school - my mom's 94 Chevy Astro. The issue was a defective EGR valve. I'm not sure if the mustang has it but a very wide range of vehicles still use them. It's an definitely exhaust issue either way. Be careful that crap will give you a bad headache after a while.
http://en.wikipedia.org/wiki/Exhaust_gas_recirculation
Old Aug 7, 2012 | 02:12 PM
airoscar's Avatar
I just find it amusing TMS is displaying food related ads on this page.
But I have noticed most cars with auto tranny gives off a smell under heavy acceleration similar to rotten eggs, not just mustangs, not sure if its the same smell you are describing
Old Sep 6, 2012 | 02:06 PM
safetyt's Avatar
I have 25k miles and the smell remains...AC is on re-circulate...taking it to the dealer...the Ford Explorer has a Service Bulletin 22386...TSB
12-8-8 3.5L TI-VCT - FOUL ODOR FROM COOLING SYSTEM - BUILT ON OR BEFORE 7/9/2012
Rando
Sep 30, 2015 12:28 PM
Mr. Sparkle
Sep 11, 2015 02:57 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
14BlackGT
Off-Topic Chatter
Sep 10, 2015 12:13 PM
Sep 8, 2015 10:45 AM
