Reverse light/camera switch + hot trans = Fail?
I've noticed that on warmer days (it hasn't even hit the 80s here yet), when I put my car into reverse (MT-82), the reverse camera won't come on. I tested it, neither do the taillights. I have to wiggle the stick around in reverse or hold it to the side to trigger the switch. I only noticed it because the reverse camera wasn't coming on one day when I had to parallel park. Thankfully, I parallel parked my GTO almost every day I had it, and that has similar dimensions and rear visibility.
Has anyone else had this problem? I'm going to have the dealer look at it when I go in for my diff howl. Might just need to be screwed in a little more or something.
I've noticed that on warmer days (it hasn't even hit the 80s here yet), when I put my car into reverse (MT-82), the reverse camera won't come on. I tested it, neither do the taillights. I have to wiggle the stick around in reverse or hold it to the side to trigger the switch. I only noticed it because the reverse camera wasn't coming on one day when I had to parallel park in Manhattan. Thankfully, I parallel parked my GTO almost every day I had it, and that has similar dimensions and rear visibility.
Haven't had that issue and I'm in Florida. It always hot. The sensor is IN the transmission I don't think you should have to wiggle it. But maybe just a loose connection? Check under the rubber shift boot.
JustangGT
4/2/21 09:22 AM
