Reverse light/camera switch + hot trans = Fail?
Old Apr 28, 2013 | 11:09 AM
lsxjunkie's Avatar
I've noticed that on warmer days (it hasn't even hit the 80s here yet), when I put my car into reverse (MT-82), the reverse camera won't come on. I tested it, neither do the taillights. I have to wiggle the stick around in reverse or hold it to the side to trigger the switch. I only noticed it because the reverse camera wasn't coming on one day when I had to parallel park. Thankfully, I parallel parked my GTO almost every day I had it, and that has similar dimensions and rear visibility.
Has anyone else had this problem? I'm going to have the dealer look at it when I go in for my diff howl. Might just need to be screwed in a little more or something.
Old Jun 12, 2013 | 01:38 PM
Spark's Avatar
Originally Posted by lsxjunkie
I've noticed that on warmer days (it hasn't even hit the 80s here yet), when I put my car into reverse (MT-82), the reverse camera won't come on. I tested it, neither do the taillights. I have to wiggle the stick around in reverse or hold it to the side to trigger the switch. I only noticed it because the reverse camera wasn't coming on one day when I had to parallel park in Manhattan. Thankfully, I parallel parked my GTO almost every day I had it, and that has similar dimensions and rear visibility.
I order my 2014 GT manual with a rear camera. Let me know what you find out.
Old Jun 16, 2013 | 06:01 PM
typesredline's Avatar
Haven't had that issue and I'm in Florida. It always hot. The sensor is IN the transmission I don't think you should have to wiggle it. But maybe just a loose connection? Check under the rubber shift boot.
JustangGT
Apr 2, 2021 09:22 AM
mambopalace
Oct 7, 2017 04:58 PM
ddejesus052389
1994-2004 V-8
Jun 1, 2016 07:04 AM
qccoles
05-09 Interior and Audio Mods
Apr 23, 2013 12:40 PM
Comox
2007-2009 Mustang GT/CS
Mar 30, 2007 04:58 AM
