Rear Wheelwells not lined completely
Old Sep 5, 2011 | 10:27 PM
Newstangowner's Avatar
It was pointed out to me today that the rear wheelwells of my new 2012 GT are not lined completely, leaving metal exposed to whatever is kicked up from the road.
The rear wheelwells are lined with a fiber material in the 2012's (the front's are still lined with plastic). That material is only covering 3/4 of the wheelwell leaving a gap (on both rear wheelwell's) toward the outer edge.
Screw up unique to my vehicle or design flaw by Ford?
Anyone know?
Last edited by Newstangowner; Sep 7, 2011 at 08:41 PM. Reason: additional information
Old Sep 7, 2011 | 02:02 PM
FordService's Avatar
Hi Newstangowner,
We need to get this looked at as soon as possible. Please bring this up to your dealer’s attention and PM me with your dealer and best daytime number (since I have your other info) so I can forward this to our Customer Care Team.
Deysha
Old Sep 7, 2011 | 03:09 PM
hahnsolo78's Avatar
Can you post pics of your problem? Not sure what you are referring too.
Old Sep 7, 2011 | 05:09 PM
05GT-O.C.D.'s Avatar
I lust for a M24
Sounds like the axle is not centered, an easy fix with an adjustable panhard bar.
Stock rims/tires/suspension?
Old Sep 7, 2011 | 06:00 PM
mystickeith50's Avatar
My thoughts exactly.
Old Sep 7, 2011 | 08:24 PM
Don't think it's an axle problem, just a lack of material problem.
I apologize if I'm not giving an accurate description.
Deysha................Im taking it to the dealer on the 19th, I'll point it out then.
Thanks for the reply.
Old Sep 7, 2011 | 08:30 PM
I lust for a M24
Completely different that what I thought you were trying to describe, good luck.
Old Sep 8, 2011 | 01:29 PM
No problem. Please, stay in contact with your CSM until the vehicle at least gets looked at by your dealer. I just want you to fully enjoy your new baby!!
Deysha
Old Sep 8, 2011 | 01:47 PM
test
test
Old Sep 8, 2011 | 01:51 PM
orange3.9stang's Avatar
On my 2011, the insualtion stops about an inch away from the outer edge of the wheelhouse and this appears to be "normal" to me. This is also the point where the sheet metal tapers away and would add complication to this molded felt insulation.
It's purpose is to absorb the noise from rain / water off the tires not to "fully insulate" the wheelhouse from the inside of the car. It does go past the tread width of the tire so it would serve it's intended purpose IMO.
I also took mine out this spring to clean above/behind them after the winter. I assumed there would be some spray-on heavy mastic type insulation behind them as has been used for years in rear wheelwells but there was nothing. The old school stuff probably did a better job, but this is obviously a cheaper, easier, and possibly more environmentally safe sound deadening solution.
Doug
Old Sep 8, 2011 | 05:37 PM
Thanks, Doug
That's how mine are also. Luckily, I won't have to drive it in the winter.
I think it's a poor design, imo. They did plastic in the front covering the entire wheelwell, why not the rear also??
-Dave
Old Sep 8, 2011 | 07:17 PM
bones302's Avatar
you can do what i did and spray in a bunch of rubberized undercoating. seals everything up nice and is good for sound insulation.
Ecostang
Nov 3, 2022 08:50 PM
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
roushcollection
Jul 28, 2015 02:08 PM
killaz05
Jul 24, 2015 08:49 AM
