outside temperature sensor
Old Sep 11, 2014 | 07:00 AM
oldnjguy's Avatar
I have a 2013 V6. It has a readout for the outside temperature. Unfortunately unlike my other fords, the temperature is extremely inaccurate. Ford had replaced the whole sending unit and it seems to be ok for a short while then goes off by 20 + degrees as I drive. I know they are not 100 % accurate, but in my other fords the readouts are within 5 degrees.
wondering what others experience has been and if anyone had found a fix for this. I'm thinking the sending unit is subject to engine heat or something similar.
Also wondering where the sending unit is ?
Old Sep 11, 2014 | 12:32 PM
dave07's Avatar
If by sending unit you mean the temperature sensor, it is behind the front bumper.
Old Sep 11, 2014 | 01:34 PM
slow.stang's Avatar
Mine seems pretty accurate, you have to keep in mind it's kinda close to the road so it will show a little high. Dave07 is right, it's behind bumper cover down by the bottom, driver side if I remember correctly.
Old Sep 13, 2014 | 07:05 AM
oldnjguy's Avatar
thanks for the help. fyi mine reads plus 10 degrees to plus20....
trackpack13gt
Jul 25, 2017 05:29 PM
Antigini-GT/CS
Oct 5, 2015 09:43 AM
