Oil under pedals on carpet! Wtf?
Old Aug 26, 2013 | 12:09 AM
YouGoGlenCocoa's Avatar
Gah lee man, sorry to hear about that. Hope they give you a new mat!
Old Aug 26, 2013 | 05:30 AM
Bucko's Avatar
Originally Posted by Coyote5-0
hahahah nice!
I really, really doubt Ford would respray the floorpans.
If it were my new Mustang that I just laid oud some hard earned cash they would. The assembly line made a goof, or a faulty part was installed; I would be intitled to be made whole again.
Old Aug 26, 2013 | 10:49 AM
dcottrell61's Avatar
Sounds like you're good underneath the carpet. I would ask fo a new mat and have the whole area cleaned, if nothing else to just remove any residual odor.
Old Aug 27, 2013 | 08:01 PM
lakersfreak's Avatar
so my invoice paper states "inspect vehicle found brake fluid leak in clutch. Master cylinder replaced clutch master and bleed system to correct concern"
Is this something I should be concerned about? Is it possible that the clutch will be forever ruined? Sorry I'm panicking
Old Aug 28, 2013 | 05:02 AM
Lime GT's Avatar
Nothing to worry about. The clutch is always engaged until you disengage it. If the clutch was affected with the leak you wouldn't have been able to shift into the next gear. The leak was minor.
Old Aug 28, 2013 | 05:13 AM
Lime GT's Avatar
I actually just removed the pedal assembly 2 weeks ago to fix squeaks coming from the clutch master cylinder and brake pedal. I had some brake fluid drip onto my carpet and just cleaned it using brake clean. Some brake clean versions are basically dry cleaning solution so I just tested it a bit on the carpet and then just sprayed the area. There wasn't much fluid loss to clean.
Gill5oh
Oct 6, 2017 10:50 PM
14Glassback
Oct 4, 2015 08:52 AM
southern stang
Sep 26, 2015 04:19 PM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
Sep 8, 2015 10:45 AM
