Map lights problem
Map lights problem
Hi guys.
Recently I realized my map lights stop working properly: they do right in all situations except when they go off once inside the car with doors closed. Switches are fine because they trigger light status on/off, but this status only shows when door opens or forcing it sliding wheel at max.
Here's a video explaining that behaviour:
P.S.: Found another post with same issue and a fuse as culprit: https://www.mustang6g.com/forums/thr...s-issue.56257/ but my model (2010 v6) has another fuse listing. I know it must be a 10-15A fuse in the interior box but can't find any dome/map lights related one. Could it be Courtesy lights one? It's the most similar...
