Map lights problem
Old Aug 8, 2020 | 10:03 AM
Kroiden's Avatar
Map lights problem
Hi guys.
Recently I realized my map lights stop working properly: they do right in all situations except when they go off once inside the car with doors closed. Switches are fine because they trigger light status on/off, but this status only shows when door opens or forcing it sliding wheel at max.
Here's a video explaining that behaviour:
P.S.: Found another post with same issue and a fuse as culprit: https://www.mustang6g.com/forums/thr...s-issue.56257/ but my model (2010 v6) has another fuse listing. I know it must be a 10-15A fuse in the interior box but can't find any dome/map lights related one. Could it be Courtesy lights one? It's the most similar...
Old Aug 10, 2020 | 03:12 PM
Kroiden's Avatar
SOLVED
It was indeed simply a fuse, don't know which one, mechanic just tested with a multimeter and replaced the gone one.
Old Aug 10, 2020 | 03:34 PM
SpectreH's Avatar
Glad it was easy fix!
Ford56860
Past Rumor Archive
12
May 25, 2020 01:46 PM
ramiro1989
May 13, 2017 03:08 PM
satch40
1994-2004 V-6
Mar 17, 2011 11:31 PM
colbymh
Jan 10, 2008 01:13 AM
allj
Oct 10, 2007 08:23 AM
