How to reset the Oil Life?
![Question](https://themustangsource.com/forums/images/icons/icon5.gif)
Took the car to a dealer over here in Virginia to have the first inspection and oil change done. Then after a day or so the display showed "Oil Life 5%". It would go away if I hit the reset-button, but the message will come back every time I start the car. Any advice how to reset that?
Unfortunately, I cannot take the car back to the dealer since right now it is sitting at the port getting ready to be shipped to Germany.
Would be great if someone knew some sort of shortcut as to how to fix this.
Ben.
Ben.
Ok, so you start the car.
Hit the setup button twice.
The message will appear "oil life #% hold Rest if new"
So... I take it you just hold the rest button and it'll go back to 100%.
Okay here is the full setup info:
1. Press and release the SETUP control to display OIL LIFE.
2. Press and hold the RESET control for 2 seconds and release.
Oil life is set to 100% and OIL LIFE SET TO 100% is displayed.
3. While OIL LIFE SET TO 100% is displayed, if a lower oil life start value is desired, press and release the RESET control to reduce the start value. Each press of the RESET control reduces the value by 10%.
Oil life start value of 100% equals 7,500 miles or six months.
Hope this helps explain this a bit.
Administrator, Shop Manual PDF Poster, Parts Locator & Spam Bot Eliminator!!
Received 2,861 Likes
![](http://cms2.fmcdealer.dealerconnection.com/NR/FordDealer/images/en/spacer.gif)
As part of Ford Motor Company's commitment to increase product quality, build vehicles that are environmentally green, and use innovative technology, we are pleased to announce the Intelligent Oil Life Monitor system. This system will be available on over 90% of the 2011 model year Ford, Lincoln and Mercury vehicles sold. The system uses information from the Powertrain Control Module and an algorithm to calculate the proper oil change interval. The interval is calculated based upon the vehicle operating conditions.
The system uses the Message Center to display when the oil needs to be changed:
- "ENGINE OIL CHANGE SOON" at 5% oil life remaining
- "OIL CHANGE REQUIRED" at 0% oil life remaining
INTELLIGENT OIL LIFE MONITOR (IOLM) SYSTEM AVAILABILITY
The IOLM will be available on most vehicles under 8500 GVWR and the all new 2011 model year 6.7L Powerstroke Diesel.
The Fiesta, Escape/Mariner Hybrid, and the Fusion/Milan/MKZ Hybrid do not use the IOLM system.
- These vehicles have a service interval of 1 year or 10,000 miles.
- They have an oil minder system that does not use an algorithm to adjust the oil change service interval.
- The minder uses a one year timer or 10,000 miles to indicate when to change the oil.
- For Fiesta vehicles only the Message Center will display: "ENGINE OIL CHANGE DUE NEXT SERVICE".
- Crown Victoria, Grand Marquis, and Town Car
- Focus
- SVT Mustang (5.4L 4valve engine)
- Ranger
- F-150 with the 6.2 liter V8 engine (Harley Davison, Lariat and Raptor)
- F-Super Duty (except 6.7L Diesel)
- E-Series
- Transit Connect
- Expedition/Navigator (5.4L 3 valve engine)
IOLM OPERATION
The IOLM algorithm uses a predetermined number of engine revolutions it would take to achieve 10,000 miles and has a timer up to one year. The IOLM then uses inputs from the Powertrain Control Module to adjust the oil change interval according to the operating conditions under which the vehicle is driven. Some examples of conditions that would accelerate the oil change interval are: trailer towing, short distance driving in colder or hotter temperatures, or the use of E85 fuel in Flex Fuel Vehicles
Customers can expect the service interval to be as follows:
- Up to 10,000 miles: Normal commuting with highway driving
- 5,000 to 7,500 miles: Trailer towing or driving with high loads
- 3,000 to 5,000 miles: Short trip usage, driving in extreme cold or hot temperatures
Note: Review the Special Operating Conditions section of the Scheduled Maintenance Chapter for exceptions.
OWNER GUIDE CHANGES
Beginning with the 2011 model year there is no longer a separate Scheduled Maintenance Guide for maintenance information. The Scheduled Maintenance Guide content is now included in the Scheduled Maintenance Chapter of the Owner Guide. The information has been reformatted for all vehicles. A chart is used for reoccurring maintenance items and a table is used for items that require service at a specific non recurring time or mile interval.
SALES AND SERVICE DEPARTMENT ACTIONS
- Review new IOLM operation with all sales and service personnel.
- Review the new Scheduled Maintenance Chapter in the Owner Guide with the customer.
- Review the IOLM operation with the customer .
- Reinforce with the customer the IOLM will determine when to change the oil on their new Ford, Lincoln or Mercury vehicle.
- If you have questions regarding the operation of the Intelligent Oil Life Monitor (IOLM) systems, please refer to the scheduled maintenance section in the Owner Guide or the Workshop Manual.
![Wink](https://themustangsource.com/forums/images/icons/icon12.gif)
The question is Each press of the RESET control "could not" reduces the value by 10%.still 100%.It doesnt work.what should i do with it ?
If you are not able to reduce the oil life value, I recommend you stop by your local Ford dealer and have them look at it for you to make sure is working properly. They can also help you set it up. If you need any further assistance, please do not hesitate to PM me.
Deysha
![Angry](https://themustangsource.com/forums/images/icons/icon8.gif)
i have a 2011 v6 mustang and i have a problem with oil life % and i can not
reduce the oil life value , i tried :
but it doesn't work it's still : OIL LIFE SET TO 100%
thanx
thanx
