Door Ajar Light
Door Ajar Light
Alright everyone I need some help. I have a 2010 Mustang GT Coupe and the “door ajar” light will not go off, I know this is a common issue but I think mine is particularly weird.
•When running a system check it says that all doors are closed and the trunk is closed.
•When I shut either door the windows still tuck up in the seal
•When I lock the car I get 2 honks instead of 1
•When anything is open (doors/trunk) it tells me exactly what is open
All of this being correct except the 2 honks when locking and yet I’m still getting a door ajar light? What sensor is bad? Is it even a sensor? Can I have someone clear it with a scanner?Am I just dumb and that’s a different light than I think or what lol? All your help would be greatly appreciated. Depending on where you see this there may or may not be pictures attached.
Edit:BUMP
I failed to read forum rules before posting here,to realize tech threads arent allowed in this forum.Try the following forum,if a moderator doesnt move this thread there first.Its the 2010-2014 forum.
https://themustangsource.com/forums/f726/
Does the interior light stay on or does it go off when the doors are shut? How about the trunk light? If you fold down the rear seat, you should be able to see if the trunk light goes off when you shut it. Just some troubleshooting ideas.
