Differential whine + leaking (photo inside)
Old May 19, 2015 | 10:13 AM
HizliBullet's Avatar
Ford changed the viscosity of the oil to get rid of the whine as "pinion leak" (under warranty) but the problem is much more than that; there's physical leakage. I can't hoist the car to see underneath but black oil in middle is obvious as another fellow with the pinion leak topic. It's in the shop today again. The whine occurs exactly at 40 mph (60 kph) only at acceleration at that speed and is audible with radio on it windows down. It doesn't happen during deceleration. My Corsa xtremes have been sitting in the trunk for 2 weeks waiting for this to be resolved.
For the record I have 3.73 6mt.
Problems I had so far are:
Engine knocking tsb: new short block replacement
#2 and #8 misfire
3.73 whine and pinion leak
Attached Thumbnails Differential whine + leaking (photo inside)-dsc_0505.jpg
Old May 19, 2015 | 10:41 AM
dave07's Avatar
Whats the picture of? Garage floor with differential fluid on it?
Old May 19, 2015 | 11:42 AM
yes thats the only proof i have since i cant get under
Old May 20, 2015 | 09:28 AM
FordServiceCA's Avatar
CURRENTLY NOT ACTIVE ON THIS SITE DO NOT USE PM FEATURE!
#2 and #8 misfire
Hey HizliBullet,
Your Mustang is in good hands with our Ford-Certified Technicians. Is it at a local dealer? Please let me know the details, including the current odometer reading. I'll see how to best assist on my end.
Mariel
Old May 20, 2015 | 05:16 PM
Originally Posted by FordServiceCA
Hey HizliBullet,
Mariel
updated with picture.
thanks mariel ford already ordered parts, its underway. the problem is differential gears, maybe its premature wear, dont know.
Old May 23, 2015 | 10:35 AM
got my car back from the shop, heres the summary of the job
CAUSE: K02
4205A REAR AXLE ASSEMBLY - IN VEHICLE DIAGNOSIS
1 CR3Z*4209*B GEAR AND PINION ASY
3 CXY*75W140*1L OIL REAR AXLE
1CXL*3* ADDITIVE OIL FRI
1 TA*29*SEALANT - SILICONE
1 3C3Z*4663*AA SHIM - DRIVING PINION
3 4R3Z*4B496*AA BOLT
4205A4 REAR AXLE RING GEAR AND PINION SET
REPLACE 4209
Steve@CJPP
Sep 3, 2015 10:43 AM
OneCoolGT
Off-Topic Chatter
Sep 3, 2015 07:50 AM
eastexsteve
Aug 17, 2015 12:07 PM
