Coyote Down!
Old Oct 20, 2014 | 05:19 AM
pminri's Avatar
Originally Posted by HizliBullet
okay so im not a mechanic at this but is this the same thing as "main bearing" we talked about in other thread? and was it after this inspection sheet that they said "ok forget it we're getting a new engine"..? now it makes perfect sense...whenever we try to record this knock its always coming from lower end under the engine...
Yes this is the same info from other thread. Engine knocks can come from several issues. Some serious like a connecting rod bearing, main crank bearing, or broken rocker arm ( a those are bad) a simple knock could come from timing being off which can lead to pre ignition even a suspension bushing being worn out.
You just don't know until the investigation starts.
After my engine was diagnosed, thee were two options. Fix everything they found (which I would have never agreed to on an engine that has 11500 miles) but I didn't have to say anything. Tasca just knew to replace it.
I believe it is easier in the long run to replace the short block anyway. Sending out the parts to be machined is a pain.
Old Oct 20, 2014 | 10:57 PM
HizliBullet's Avatar
holy crap! i do have noisy front suspension bushings too! but what does that have to do with engine block parts?
Old Oct 21, 2014 | 05:23 AM
pminri's Avatar
I was just trying to give you examples of where knocking sounds in general can come from.
Old Oct 21, 2014 | 08:09 PM
I drove the 2015 GT today btw....bullitt green with tan interior
Coyote5-0
Oct 12, 2015 10:44 AM
FromZto5
75
Oct 5, 2015 02:27 PM
MRGTX
Sep 8, 2015 03:19 AM
JTB
Motorsports
Sep 7, 2015 10:20 PM
BavarianStang
Sep 5, 2015 05:55 AM
