Clutch Blown?
Clutch Blown?
Clutch was acting completely normal, until I u-turned and accelerated quickly and the clutch pedal stuck at high RPM. When I got home, there was definitely clutch smell and jumpiness in the pedals when I try drive. Not looking good.
I attempted to drive it. I let it sit over night. It is not doing what it did last night. Everything feels normal besides a slight chatter at the catch point from 1st to 2nd only
I had the issue and now I have a grinding noise while shifting into 5th gear, so I am going to replace the clutch line with this as soon as I can get Ford to fix my transmission.
Do you remember if the problem happened when you were trying to shift up from 2nd into 3rd gear? That seems to be where I have the issue with mine, high RPM's trying to shift up from 2nd into 3rd gear.
It happened mainly from 1st to 2nd but maybe like once from 2nd to 3rd. The clutch feel seems to be back to complete normal but like you said I ordered the Mcleod line from American Muscle
9/23/15 03:21 PM
JonathonK
9/19/15 03:19 AM
