Clicking Noise from Dash When Switching Airflow Direction
Take a look at post 14 in this thread. It links you to another forum that shows the detailed part information.
This is the direct link to that other forum.
Ok,today i've pull down glovebox and
I tried disconnecting the connectors from the actuators...
Should be the upper actuator (with an arrow in the picture),because if I disconnect the connector noise disappears ... although to be honest , the selector of the air does the same...What's the name of this actuator please?
In rockauto.com i've found this replacement part...
It's ok?
http://www.rockauto.com/catalog/more...nid=589&jpid=0
It's ok?
Originally Posted by Giuseppe Murolo
Do you happen to know where this Blend Door is located?
I received a new one and was going to replace it myself.
ssjbuu
8/28/15 08:55 AM
