Car is off by 20 mph after 3rd gear
Old Aug 5, 2013 | 08:11 PM
Joshua Szukalski's Avatar
I recently had my car in the shop because I was driving it and it cut completely off on me with on coming traffic. I had to get the car towed cause it had no power to move. The idle was all off and the air fuel ratio was all over the place. They replaced all the injectors and the pcm. Now my speedometer is off by 20 mph and ford said there is nothing they can do about it. My car has just over 2000 miles on it.
Any suggestions. I didnt change the tire size or the gears.
Old Aug 6, 2013 | 06:49 AM
AzPete's Avatar
Sounds like they didn't program the correct gear ratio and tire size..... I would see about another dealer plus contact the Ford reps on here....
Old Aug 6, 2013 | 09:33 PM
Its been to 3 dealers 1 dealership in texas that did all the warranty work. Which i had to fight for them to do. And then 2 in maryland. They said i need to get an aftermarket tune to correct the problem which i know isnt true.
Old Aug 7, 2013 | 09:13 AM
AzPete's Avatar
Well....sounds like some bs somewhere....if the mph is off, so is the odometer off too.... which can seriously effect the warranty and car value.
Are the tires, wheels, and rear end gears all the stock items?
An after market tune may void the warranty.....
Old Aug 7, 2013 | 05:16 PM
All is has is the boss 302 intake on it which i bought it from the dealership like that with 18 miles on it. Then it has the boss 302 rims on it and the gears and rear end are stock. It is lowered on sportlines and has a roush axelback exhaust.
Old Aug 7, 2013 | 05:17 PM
Everything was fine, till the car had to be towed into the dealership and they did warranty work.
Old Aug 7, 2013 | 05:39 PM
Rather B.Blown's Avatar
Like Father...
I ♥ Sausage
I thought the Boss intake required a different tune?
Old Aug 7, 2013 | 05:47 PM
Sounds like the PCM doesn't match your gear ratio.
Old Aug 7, 2013 | 06:50 PM
Me to the car did have a ford racing tune on it, if they put it on the car when they replaced it i dont know.
Old Aug 7, 2013 | 06:51 PM
Thats what i said to them and they said there is nothing they can do. just go see if the state police will calibrate the car or get an aftermarket tune on the car.
Old Aug 7, 2013 | 06:56 PM
Hadtohaveit'13's Avatar
They want you to after market tune it so they can write you off. They should definitely fix it. You mentioned boss wheels though. Those are 18's, did you go down from a 19?
Old Aug 7, 2013 | 07:52 PM
AzPete's Avatar
What part of the world are you in?
Old Aug 7, 2013 | 08:26 PM
I know they want to do that. The boss rims I have are 19s.
Old Aug 7, 2013 | 08:27 PM
I was in Texas but now I am back to my Hometown in Maryland.
Old Aug 7, 2013 | 08:41 PM
AzPete's Avatar
You might contact the Ford rep online, Deysha, she has good connections.
Old Aug 7, 2013 | 08:55 PM
How do I contact her ?
Old Aug 8, 2013 | 07:01 AM
AzPete's Avatar
Deysha private message... https://themustangsource.com/private...newpm&u=111098 Really surprised she has not responded here by now.
Old Aug 13, 2013 | 09:24 AM
FordService's Avatar
Hello Joshua Szukalski,
My name is Deysha with Ford Service. Even though you have some aftermarket things on your vehicle, I recommend you make an appointment for diagnosis. Also, PM me with your dealer, full name, VIN, mileage, and best daytime number so I can escalate this for you and make sure it’s not a manufacturer’s defect.
Please keep in mind, if these aftermarket parts are the cause of your concern, that specific repair will not be covered. You will need to contact your vendor for assistance.
Thank you for the mention, AzPete.
Deysha
Jim74656
May 1, 2023 02:15 AM
sarnold58
Jun 9, 2019 02:22 PM
ssjbuu
Aug 28, 2015 08:55 AM
Bullitt 3309
Aug 2, 2015 10:20 PM
chadh92
Jul 29, 2015 06:56 AM
