Advance trac need service...
Old Feb 17, 2012 | 03:41 PM
Jcint's Avatar
So out of the blue my dash on my 2011 reads ' ADVANCE TRAC NEED SERVICE" my traction control symbol is on "off" and my driver side airbag is symbol is on too. I did a quick search and found that alot of 2010 and 2011 are getting this message and it could be traced back to a electronic module under the airbox that is failing OR if you changed your exhuast you might be melting a wire under the car near the mufflers......hmmmmmm I guess i'll find out monday when ford checks out my car.
Old Feb 17, 2012 | 04:06 PM
Jza1736's Avatar
A couple of Boss owners are having this issue. I've had it 1 time. I shut the car off, it reset and hasn't happened again
Old Feb 17, 2012 | 06:50 PM
Jcint's Avatar
Cleared it with my tuner but it comes right back. Ohwell lets see what they say monday.
Old Feb 20, 2012 | 11:12 PM
Jcint's Avatar
Well service dept was alittle baffled as to why the driver airbag warning light is on with the traction control light. After about 4 hrs they called me and said it's a sensor module that failed and they have to order it. As soon as i find out the exact name of it I'll post it. On another note ( I tryed this and it didn't work for me) A buddy of mine had the same issue after he changed his exhuast, but he found a fix online and it cleared up his codes. here is the fix...STEP ON YOUR BRAKE AND TRACTION BUTTON AT THE SAME TIME FOR 8 SEC. TURN OFF CAR COMPLETELY AND WAIT A FEW SECONDS, MAKE SUFE EVERYTHING IS OFF. TURN ON THE CAR. He said it cleared all his codes and he hasn't had any issues since.
Old Feb 22, 2012 | 03:29 PM
Jcint's Avatar
Well here is the part replaced.... "RESTRAINT CONTROL MODUEL (RCM)" Ok here is the kicker........ After all this, It was actually a blown fuse! Mecahnic said i had a 10amp fuse where a 15 was suppose to be. I told him i NEVER changed any fuse so whatever was there came from the factory like that. He was trying to make it seem like I put the wrong fuse in there. FIXED!
Fastnloud
Feb 15, 2016 05:21 PM
boz
Oct 1, 2015 04:47 PM
Fred_Garvin
Sep 17, 2015 04:10 PM
Sep 16, 2015 06:44 PM
jim010
Sep 14, 2015 10:15 PM
