2011 gt keeps overheating at idle??
Old May 14, 2019 | 12:37 PM
Austin Hagle's Avatar
So my 2011 mustang gt will occasionally overheat on a hot day at idle I already changed the thermostat and it still overheats anyone know why??
Old May 14, 2019 | 12:52 PM
SpectreH's Avatar
Is the fan coming on?
Old May 14, 2019 | 01:35 PM
Yeah I think so I'm not sure if it's on when it starts overheating when ever it over heats I try to drive it as fast as possible so it can cool down I never had a chance to get out and look at it
Old May 14, 2019 | 02:17 PM
Bert's Avatar
yep most likely the fan is not coming on, or not coming on soon enough
there are two fan speed settings, hi and low, which kick on at a defined temperature which can be adjusted in the tune -- so if you installed a new tune shortly before this started happening, that could be the cause (but most tunes turn them on sooner rather than later)
otherwise it is probably the relay, if I remember correctly from other threads I have seen on here -- you should be able to find them, with the details, using "search" feature
one quick and easy way to test: turn on the A/C; the fan should come on when the A/C is on . . . if you let it idle with the hood open it could take a while but that is the best test
Old May 16, 2019 | 06:31 AM
Thank you very much I will try that and hope that's the problem
dj050894
Jul 21, 2024 07:57 AM
PJRManagement
61
May 18, 2015 08:59 PM
Stix66
Mar 26, 2008 09:14 PM
KrisHorton
17
Jan 14, 2008 08:37 PM
