Want to change OEM 8" door woofer to 6.5"
Old Jan 27, 2014 | 05:33 PM
califsp's Avatar
I have some good 6.5" 2 ohm woofers from a component set. I want to take out the factory 8" subs/woofers and put in the 6.5" woofers. I have the 8" to 6.5" adapters. I checked and there's plenty of room. I want to use the factory amp. How do I wire them in? I've already changed out the rest of the speakers and added a sub. Thanks to anyone who can help.
Old Jan 28, 2014 | 09:07 AM
DeeJayTJ's Avatar
you have to wire them so that they are 2ohm, it depends on what speakers you get tho, which do you have in mind?
Old Jan 28, 2014 | 09:14 AM
califsp's Avatar
I found the answer. Since the OEM woofer is dual voice coil, it has two sets of wires connected to it. I just need to connect one set to the new woofer.
Old Apr 6, 2014 | 09:52 AM
firestang's Avatar
Where did you find the 8" to 6.5" adapters?
Old Apr 8, 2014 | 06:09 AM
Rando's Avatar
This
Old Apr 8, 2014 | 09:14 AM
califsp's Avatar
They don't exist. I had to make my own using a rotozip. I love the sound by the way. And it looks stock because you retain the factory grill.
Old Apr 8, 2014 | 09:33 AM
This could help you in the future, as well as anyone else reading here
http://www.the12volt.com/caraudio/wo...igurations.asp
Autotooner
Nov 24, 2017 12:42 PM
ricky1728
Feb 11, 2016 07:25 PM
DerekShiekhi
Sep 30, 2015 06:59 AM
