Which sub and amp?
Old Nov 25, 2013 | 10:21 AM
tostang's Avatar
Which sub and amp?
Hi there. it looks like a few people have added a sub or subs to their cars. I'm looking to add a sub or two subs and an amp to my Shaker 500 system. I'm not looking to swap the HU at this time.
Apart from learning that it can be done; What amps (boxes) fit and what did you end up going with?
I like JL Audio, but I'm at a loss as to which box would be best?
thanks!
Old Nov 25, 2013 | 03:28 PM
ColSaulTigh's Avatar
What's your budget?
Old Nov 25, 2013 | 03:36 PM
tostang's Avatar
1000.00 or less.
I have a convertible, I was looking into the JL Stealthbox, but it doesn't fit in a 'vert...!
Any advice is appreciated.
Cheers,
Paul.
Old Nov 26, 2013 | 02:16 PM
Should be no problem to hit that budget point. I would go with having a custom box made by a local shop. Anyone good with fiberglass and math can build you a "stealth" box for your 'vert. Buy the JL driver and amp separately, and you're in business!
Old Nov 27, 2013 | 09:07 PM
tostang's Avatar
Thanks for the advice!
Old Dec 5, 2013 | 02:41 PM
ghjr's Avatar
I run an Alpine SBR 8" sub powered with and Alpine MRX-M55 (350 watts). You have to hear this little sub to believe it! I have it in the right rear of the trunk.
Old Jan 23, 2014 | 07:36 PM
Shipey's Avatar
Originally Posted by tostang
1000.00 or less.
Cheers,
Paul.
You could replace the door sub amp with a small aftermarket unit to fit in the same location, and replace the 8" door subs with 6.5" on adapters. You could have better bass (without a sub in the trunk) and a stock appearing installation that uses the factory grills and trim rings.
Old Feb 1, 2014 | 07:00 PM
Shipey's Avatar
When the warm weather gets here, I will be trying CDT Audio QES-680 on adapters with my Arc Audio KS Mini 125.2 (75W @ 4 ohms) which is already installed in the stock door amp location. I am hoping this is the answer for good bass in the car without a sub in the trunk. We'll see.
Old Feb 1, 2014 | 08:34 PM
southcarolina12's Avatar
i put in a 12 inch L3 and kicker DX500.1 amp in a generic ported box. it sounded good it made my driver side mirror fall off and shatter and made my rear view mirror rattle like crazy so i took it out. needless to say it was too loud for a little car like a mustang imo.
Old Feb 1, 2014 | 09:54 PM
tostang's Avatar
I bought a Rockford Fosgate Punch P300 "12 powered sub, plus a pair of Infinity Kappa 682's for the doors.
This years long a$$ winter is making me antsy. Can't wait to install them, when some decent weather arrives!
Old Feb 11, 2014 | 09:28 AM
BJPGOLFNUT's Avatar
I have two Rockford Fosgate 10's. I kept the stock head unit and used a line out converter for the signal.
Old Feb 18, 2014 | 06:49 PM
zbrewha863's Avatar
First, you will need a line output converter if you are not using a head unit. That will transform your speaker-level outputs into line-level inputs that an amp can take (unless you buy an amp that accepts speaker-level inputs).
FWIW, I went with one 10" Infinity Kappa Perfect sub in a custom MDF box -- cost me $250 for the sub and I think $75-100 for the box. For the amp, I went with a JL 250/1 amp (I think I paid $150 used for it) and the combo sounds amazing, very detailed but will rattle the car if you want.
I paired this with 2 JL Audio 8w1v2 subs in the doors ($150/pair) with an Xtant 302a amp ($250 used) and they sound fantastic. I had to cut the inside of the door panels a little because even though the magnets are technically shallow enough, the basket is so large that it hit the waveguide thing in the door panels.
That puts you right at $1,000 by the time you add in sound deadener and wiring. Please get some sound deadener. Don't be that guy.
Old Feb 22, 2014 | 06:38 PM
SterlingGrayGT's Avatar
Im looking into a Pioneer shallow mount 12' Subwoofer and an Alpine 500w mono block class D amp to round out the sound and add some low end to my radio. I have had good experience with this kind of setup before.
BigHoss
Sep 21, 2015 10:03 AM
RCooke08GT
05-09 Interior and Audio Mods
Sep 1, 2015 08:07 PM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
K.A.I.N
Jul 20, 2015 06:42 AM
staindreality
Nov 17, 2004 06:30 PM
