Rockford Fosgate P3SD2-8 door sub
Old Jan 2, 2013 | 06:21 PM
Shipey's Avatar
Anybody happy using these with the stock door sub amp(s)? Apparently little to no users of the Helix 2 ohm DVC subs. These RF subs are also 2 ohm DVC and may be a decent match to the stock audio system.
Thanks.
Shipey
Old Jan 2, 2013 | 06:27 PM
Helix is not a very known brand, but they make high end good quality stuff. If you can swing it, I'd much rather take a chance on trying some Helix drivers versus RF crap that they sell at best buy...
Old Jan 2, 2013 | 07:08 PM
hawkeye18's Avatar
http://www.helixhifi.com/products/pr...tem_id=142203#
http://www.rockfordfosgate.com/produ...?itemid=233191
http://www.pioneerelectronics.com/PU...ount/TS-SW841D
^ That's a single 4ohm coil sub, but it'd fit.
Old Jan 2, 2013 | 07:26 PM
DrDisney's Avatar
Will these all fit in the door with the existing speaker covers? And the first two are 2 ohm so they should work without any extra amplification? Anyone use any of these?
Old Jan 3, 2013 | 04:34 AM
Shipey's Avatar
According to mfgr's specifications, the overall diameter of Helix is 8.3" and the Rockford Fosgate is 8.72". The stock speaker measures 8.5", so I believe using either of these in place of the stock speaker with the stock grille and trim ring will require modification to the speaker, the stock grille, or both.
Of course you can't really know unless you take the plunge and buy one to try. I'm tired of wasting money on purchases for my car that don't work out, and was hoping someone here had a good replacement speaker experience with the stock amps.
Old Jan 3, 2013 | 05:33 AM
DrDisney's Avatar
The only one I know for sure is the Kicker sub by Shelby but it requires their grill cover.
Old Jan 3, 2013 | 05:25 PM
Shipey's Avatar
Yea. The stockers already come too far into the interior, and those Kickers are even worse. Also, I get the impression that their power requirement does not work well with the stock Ford door sub amp. It's my goal to get a good sounding speaker on the stock amp.
Old Jan 3, 2013 | 05:28 PM
Do you have a router/jigsaw, or access to one? It's a lot easier to make a ring for something that's 2/10 of an inch small, than it is to trim something that's too big for the stock cover...
Old Jan 4, 2013 | 06:59 AM
Shipey's Avatar
I'm looking into that as a solution. Thanks.
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
Mustang65bob
Sep 21, 2015 11:30 AM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
