Removing door panels
Old Oct 5, 2011 | 07:21 PM
rmurad38's Avatar
Hello all,
I have seen videos online showing how to remove the door panels, I have followed them and the panels are easy enough to remove (most of the way) My question is, how do you detach the cables from the interior door panels? does it require a special tool? I tried doing this by hand, got the cable detached from the door pull, but no matter what i tried, I could not detach the cable from the actual door panel.. it took quite some time to get the cable back in to the handle, not fun..I gave up and just put the door back together.
Any help would be appreciated, I want to fully remove the panels to modify them.
thanks!
rmurad38
Old Oct 6, 2011 | 06:47 PM
I have no clue. No visable clip on them any where? Why do you want to remove them?
Old Oct 6, 2011 | 08:41 PM
rmurad38's Avatar
want to completely remove them to be able to bring the panels into the house to properly apply sound deadening to them, better light, warmer, cleaner, etc..The JLT youtube video briefly mentions clips "you can't see" ill just have to pull them again and look
rmurad38
Old Oct 7, 2011 | 07:19 AM
good call on the sound deadner. It really made my car nicer to take those long trips in. I didn't put and on the door panels tho just inside the door. Hmmmmm I should check mine out to see if there is any room to apply some to my panels. I was afraid it would be to thick and make the panel stick out.
Old Oct 7, 2011 | 07:42 PM
wonger's Avatar
The green clips on the cables WILL depress. It helps to rotate them at the same time.
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
