IOS6 mod
Old Sep 19, 2012 | 05:49 PM
12GTCS's Avatar
IOS6 mod
So I downloaded IOS6 tonight and it says it supports MAP for Bluetooth. That should allow us to have text via voice functionality now right? Can't get to the car to test it tonight, but this would be great if it is the case...
Old Sep 19, 2012 | 06:46 PM
mac951's Avatar
Apple is so overrated!
- Sent from my iPhone
Old Sep 19, 2012 | 06:47 PM
11SHELBYGT500's Avatar
Have you checked the stock price? Lol
Old Sep 20, 2012 | 06:43 AM
CHDS PNY's Avatar
mine doesnt say "Phone not supported" anymore but it errors when downloading messages and wont send either
Old Sep 20, 2012 | 06:47 AM
Tight Lines's Avatar
Mine still says not supported.
Old Sep 20, 2012 | 07:03 AM
12GTCS's Avatar
After doing some digging it looks like you have to repair the connection to your phone or delete your phone out and reconnect it. I'll test it at lunch...
Old Sep 20, 2012 | 08:15 AM
Look forward to hearing if this works.
Old Sep 20, 2012 | 08:42 AM
12GTCS's Avatar
Same deal here. I deleted and re-loaded my phone. I now have access to all of the texting functionality, but it fails every time. I seem to remember a sync engineer type on the forum in one of these posts, maybe they can shed some light....
Old Sep 20, 2012 | 10:35 AM
newpony's Avatar
It doesn't work with my iPhone 4 even after deleting and adding it again.
Is MAP only supported on 4S and/or 5?
Old Sep 20, 2012 | 10:49 AM
CHDS PNY's Avatar
mine's a 4s
i will get my 5 tommorow
Old Sep 20, 2012 | 11:36 AM
newpony's Avatar
According to this guy it should work with the iPhone 4. The profile needs to be deleted on both the car's system AND iPhone then reconnect.
http://forums.macnn.com/t/492684/for...rofile-how-too
Ok so I have been seeing confusion all over the web today about if its working or not. If its working on anything other then the iPhone 4S and 5 or not and so on. Im here to clear it up. I had to wait until later in the day to do the update so like many I had been searching online about the Blue Tooth MAP which was in the beta.
To clear things up
YES - Bluetooth MAP (Message Access Profile) works on 4 and I suspect on 3GS too.
YES - It made it to the final software
YES - it does work with Ford Sync 3.1 and up
I don't know if it works right with Ford My Touch, some one else will have to test that out.
Anyways if you update the phone and try to use it the Ford Sync will continue to say not supported.
You MUST Sync from the phone and then delete the Phone from Ford Sync
After you have done this re-link Sync to your iPhone and this time around the Ford Sync will see the BT MAP
Additionally in the phone if you go to details under Sync you will see a option "Show Notifications" with a slider on and off. By default its off. You need to turn that on.
If you don't delete Sync from the phone and the profile from the car first, that Show Notifications option will not be there.
I hope this helps.
This probably will apply to many of the Car systems from BMW, Honda, Fords My Touch system for those upgrading phones. Hope others test that out on the other cars to confirm it
He made a video too.
http://youtu.be/8LcrYY9V7_w
Old Sep 20, 2012 | 12:46 PM
newpony's Avatar
Still doesn't work for me Still says not supported. My car has the NAV option aka Electronic Package.
Old Sep 20, 2012 | 12:57 PM
CHDS PNY's Avatar
mine has nav
i did all that and i can get into messages but that is all
what i really want is the bluetooth for streaming :arg:
Old Sep 20, 2012 | 01:27 PM
newpony's Avatar
The streaming has always worked for me even with my old iPhone 3G.
Old Sep 20, 2012 | 01:30 PM
Originally Posted by CHDS PNY
mine has nav
Yeah, are you saying you can't stream with Bluetooth CHDS PNY?
Old Sep 20, 2012 | 01:47 PM
CHDS PNY's Avatar
Streaming all the time...I mean song titles and artists
Old Sep 20, 2012 | 02:17 PM
newpony's Avatar
Ok. Yeah I'd like that too but isn't this a SYNC/MyTouch thing, meaning it doesn't do it for any phone?
Old Sep 20, 2012 | 02:25 PM
Why do you need that? That info is on your phone.
Old Sep 20, 2012 | 02:33 PM
newpony's Avatar
Convenience plus a little safer than picking up your phone to look at it.
Old Sep 20, 2012 | 04:26 PM
Mine doesn't work either. Will it work on 2011 Nav unit?
