HELP car shut off 5 times while driving after sub install
Old Nov 14, 2012 | 09:51 AM
Ghost.223's Avatar
UPDATE POST 11. not fixed
First I need to know if I installed the battery cable from battery to powered sub in the right spot. There are 3 bolts with wires already connected to the battery so I just undid the top bolt and added the cable on top of the one already there. Is that the correct spot?
Old Nov 14, 2012 | 10:32 AM
Ghost.223's Avatar
There is a pic of the battery connector in my album photos sense I can't seem to post it. It shows the top bolt I'm talking about and the wires connected to it but I removed the sub power cable from it till I know if its the correct spot
Can add details. B-8p 8 inch 80 watt sub.
Uses speaker level inputs. No prob
Ground: used seat belt bolt, scratched off paint and installed. If this was not done right I imagine the sub would not work which it does fine.
Remote turn on was recommended to wrap around wiper fuse under dash. #45 was what I used, (Wiper relay and module, Blower relay). disconnected after 4th time car died which turned off sub and car still died again.
That just leaves power wire, what could be causing it to kill car?
Old Nov 14, 2012 | 10:37 AM
Bucko's Avatar
The red rubber protector is battery "+" (positive), the other is ground. Not sure what you mean by "powered sub"; is this a sub woofer you are refering to? I can't believe it's drawing too much power from the battery to shut it down. Did you install a fuse between this connection of the battery to the powered sub? Is this wre getting warm or hot?
Posting the picture for you:
Old Nov 14, 2012 | 10:51 AM
Ghost.223's Avatar
Thanks for the pic. Dead center in pic is where I installed it, right over top of the other wires that trail off to the right.
Yes a powered subwoofer and there is a 25 watt fuse a foot into the line on the power cord from the battery. Nothin really felt hot.
Old Nov 14, 2012 | 03:02 PM
Bucko's Avatar
From your symtoms, it almost sounds like the battery is falling below a specified voltage, and the PCM is shutting down. I'm going to read the diagnostic part on this tonight (downloaded the 2011 factory repair manuals). This has me curious.
Old Nov 14, 2012 | 03:14 PM
Ghost.223's Avatar
Cool thanks. When it shuts down all electronics are still on including radio although the last shut down I had the radio shut fully off. Engine dies then 3 seconds later the dash lights up with warning lights like its WW3.
When the car comes to stop I put in park and have to wait a full minute to restart or it will not crank at all but again have full power the whole time, no dim lights or anything hinting at low power.
Old Nov 14, 2012 | 04:36 PM
CaptDistraction's Avatar
loose ground on battery? make sure all the cables are tight to spec. Even a slightly loose but firm cable can cause weird issues like that.
Old Nov 14, 2012 | 05:44 PM
TheDivaDanielle's Avatar
loose cable. open/shut case.
Old Nov 14, 2012 | 07:36 PM
Ghost.223's Avatar
Tightened everything up and took 3 drives. So far so good
Old Nov 14, 2012 | 08:20 PM
Bingo!!!
Another satisfied member
Old Nov 16, 2012 | 01:19 PM
Ghost.223's Avatar
UPDATE: NOT FIXED
Was okay for those 3 little drives then happened again and again. Re fixed clamps 3 times with no help. Disconnected power sub wire as well and still happened.
At ford now being looked at and will update.
Of 10 times car shut down in last 2 days 3 were off the line giving it a lot of gas and most of the rest were right after hitting large bumps in the road.
Old Nov 16, 2012 | 02:23 PM
Ghost.223's Avatar
Just got word car is ready, they found a short leading to the PCM and when they followed it down found a peice of a wire underneath the computer causing it. I think I heard that right but I'm not too good at understanding all the electrical stuff he told me ha ha.
Old Nov 20, 2012 | 10:21 PM
skullzero's Avatar
that is a crazy situation i never heard of anything like the issues that you are having with the short
Old Nov 21, 2012 | 06:16 AM
Ghost.223's Avatar
Yep it was, service manager said it was a defect from the manufacturer but just happened to not cause any issues until suddenly. At least I did not cause it ha ha.
Old Nov 21, 2012 | 07:07 AM
wheelman's Avatar
Cool that it was found/fixed now rather than sometime down the road, in a crappy situation, with no more warranty.
Jim74656
May 1, 2023 02:15 AM
ssjbuu
Aug 28, 2015 08:55 AM
trackpack13gt
Aug 8, 2015 11:23 AM
Rodsmustang
Which is Better
Jul 14, 2015 02:09 PM
