Has anyone added the 8" Kicker Door Subs to the Stock System?
Old Apr 3, 2013 | 09:40 AM
BadHabit2Break's Avatar
The Shelby/Kicker 8's are 4ohm speakers compared to the OEM 2ohm speakers.
So adding the Shelby/Kicker 8's will reduce the power that the amp puts out by half.
So just replacing the stock HU to an aftermarket will not do the trick. You will either have to go aftermarket amp or buy the Shelby/Kicker amp.
I have the Shelby/Kicker door speakers and door subs but I am still running the OEM Shaker 500 amp for the door subs.
Old Apr 3, 2013 | 12:40 PM
mac951's Avatar
How do the door subs sound? Better? Worse? Worth it? I'm thinking of getting some for a clearer sound but don't want to go to a after market amp.
Old Apr 3, 2013 | 01:27 PM
They are not as loud as the OEM subs. So there fore I have to say worse due to the lack of power from the OEM amp.
Old Apr 3, 2013 | 05:43 PM
mac951's Avatar
Gotcha, thanks for the reply btw!
Old Apr 7, 2013 | 11:51 AM
iScream's Avatar
Can anyone tell me the specs on the Shelby Kicker 8's? Are they single voicecoil or dual and what is the Ohm rating per voicecoil? What is the power handling?
I'm thinking about replacing my door subs with a set of these, with an amplifier, but I don't see specs on the Shelby website.
Old Apr 7, 2013 | 09:32 PM
Skeetch11's Avatar
My question was whether anyone had swapped the head unit and got the kicker subs. Sounds like you haven't... I get that the impedance is higher, and so the output will be lower. But the stock HU sends a pretty crappy signal, and my stock speakers sound a ton better with the new one. So I'm still wondering if anyone has an aftermarket HU and the Shelby 8's.
Old Apr 17, 2013 | 07:52 PM
iScream's Avatar
I'll answer my own question here. I called Shelby and they gave me a number to call Kicker. Not sure where BadHabit2Break got the info he posted above but Kicker says the door woofers ( can't bring myself to call them subwoofers ) are single voicecoil and they are 2 Ohm impedance. The power handling is 200 Watts RMS each.
I should have a set installed in about a month, driven by a little over 200 Watts per channel. I plan to bandpass them at something like 70 Hz to 200 Hz, depending on how it sounds and where I end up crossing over the sub I'm adding in the trunk.
If anyone is interested, I'll post back with how it turns out.
Old Apr 17, 2013 | 08:41 PM
Mr. V's Avatar
I'm very interested to hear/read what your results were. Good luck!
Old Jan 24, 2014 | 06:28 AM
SeanD's Avatar
any updates on how the Shelby Kicker door "subs" sound. I am looking into getting them.
Ecostang
Nov 3, 2022 08:50 PM
HizliBullet
GT350
14
Nov 14, 2015 08:59 AM
MartinM
Sep 19, 2015 02:11 PM
TonyJestis
Aug 21, 2015 06:06 PM
forceflow2
'10-14 Interior and Audio
Aug 4, 2015 08:02 PM
