Door panel insert removal?
Old Nov 19, 2013 | 01:57 PM
numnutz's Avatar
Can anyone tell me how to remove the door panel insert directly above the armrest on 2012 base convertible? Does it snap out, or will I have to remove the complete door panel? Thanks.
Old Nov 19, 2013 | 02:28 PM
southcarolina12's Avatar
it looked to me like its molded to it when i had my door panel off last week.
Old Nov 19, 2013 | 05:59 PM
numnutz's Avatar
Thanks. I was hoping it would snap apart like the other plastic pieces. Thanks again.
Old Nov 19, 2013 | 07:05 PM
zbrewha863's Avatar
It definitely comes off because I have seen it replaced, like on the MRT Mustang. Next time my door panels are off, I will check!
Old Nov 19, 2013 | 08:25 PM
RubyRedMCA_Beast's Avatar
It may be 'plastic welded' in or whatever it's called. Meaning you might have to cut/drill plastic to remove it. I don't know for sure.
Old Nov 21, 2013 | 03:43 AM
Stevedotmil's Avatar
I have been wondering this same ruins because I want to cover mine in suede instead of the pleather that it came with standard. So it will finally match my shift boot I made. I used ultra suede on the shift boot though so I might redo that as well. Shift boot is my build thread in case anyone was wondering.
Old Nov 21, 2013 | 07:20 AM
ColSaulTigh's Avatar
It's glued in place. Heat gun to the BACK side and some prying might remove it...
Old Nov 21, 2013 | 09:22 AM
numnutz's Avatar
Thanks for a definitive answer; sadly I ain't that brave. Thanks again. Can of SEM still looks like the solution.
May 3, 2026 05:42 AM
RCooke08GT
Feb 19, 2017 03:03 AM
09-gt/cs
Oct 15, 2015 10:03 AM
