Console Removal - Premium GT
Old Jul 31, 2014 | 06:18 PM
2014DIB's Avatar
Trying to completely detach the console so I can remove it from the car for an upcoming audio install.
Removal of the Trunk/Flasher connector toward the front left - no problem.
Since it is premium - there are also two connectors for the cup-holder/ambient lights, one green and one gray.
Green one - no problem. Depress latch and car side unplugs.
Gray one - for the the life of me, I could figure out how to disconnect, so I could completely detach the console. Hard to see in the pic but this one also has two white plastic "friction" attachments that hold the entire connector assembly to the underside of the console. Perhaps the heat was shutting down my brain!
Any suggestions?
Old Aug 8, 2014 | 12:03 PM
05PRMTX's Avatar
I think I've ran into connectors like this before, judging by the pic. They can be a pain in the you know what. If you can get a screw driver in there with decent leverage, push down and up...maybe pull a little too on the part that moves, it should pop out...
oneeyedgiant
Nov 16, 2015 12:23 PM
oneeyedgiant
Sep 29, 2015 01:33 PM
y5e06
Sep 21, 2015 08:05 AM
