Base radio /double DIN conversion
Old Jan 6, 2015 | 06:13 AM
SpeedyJoe's Avatar
I am planning to change my basic radio on my 2013 V6 to a Pioneer nav radio (double DIN) with the metra kit 99-5823ch without the touchscreen for the climate control. Can anybody tell what exactly I need to get that done, besides the radio and the metra kit?!
Old Jan 7, 2015 | 11:15 AM
05PRMTX's Avatar
I am doing this as well. You will need 2 more things.
The harness:
http://www.crutchfield.com/p_541RP4F...Interface.html
The antenna adapter:
http://www.crutchfield.com/p_12040CR...a-Adapter.html
You may want this too. Parking break bypass. Make sure its the right one for your radio first.
Amazon.com: MicroBypass Video In Motion Interface For Use With Pioneer Models AVH-100DVD AVH-170DVD AVH-200BT AVH-270BT AVH-X1500DVD AVH-X1600DVD AVH-X1700S AVH-X2500BT AVH-X2600BT AVH-X2700BS AVH-X3500BHS AVH-X3600BHS AVH-X3700BHS AVH-X4500BT AVH-X4600BT AVH-4700BS AVH-X5500BHS AVH-X5600BHS AVH-X5700BHS AVH-X6500DVD AVH-X6700DVD AVH-X7500BT AVH-X7700BT AVH-P8400BH AVH-X8500BHS AppRadio2 AppRadio3 AppRadio4 SPH-DA100 SPH-DA110 SPH-DA120 SPH-DA210 AVH-4000NEX: Electronics Amazon.com: MicroBypass Video In Motion Interface For Use With Pioneer Models AVH-100DVD AVH-170DVD AVH-200BT AVH-270BT AVH-X1500DVD AVH-X1600DVD AVH-X1700S AVH-X2500BT AVH-X2600BT AVH-X2700BS AVH-X3500BHS AVH-X3600BHS AVH-X3700BHS AVH-X4500BT AVH-X4600BT AVH-4700BS AVH-X5500BHS AVH-X5600BHS AVH-X5700BHS AVH-X6500DVD AVH-X6700DVD AVH-X7500BT AVH-X7700BT AVH-P8400BH AVH-X8500BHS AppRadio2 AppRadio3 AppRadio4 SPH-DA100 SPH-DA110 SPH-DA120 SPH-DA210 AVH-4000NEX: Electronics
The first two are crutchfield links, you can find them cheaper on amazon and ebay.
Old Jan 11, 2015 | 12:45 AM
SpeedyJoe's Avatar
The antenna + harness adapters I already ordered, but I won't need the Bypass cause I am not using my Alpine for videos. The harness is a more basic version without the steering wheel connection.
Additionally I am installing a USB connector into the centre console to make the USB usable.
Where are you going to install the GPS antenna? I've seen installs at the windscreen or on the dash, any idea?
Old Jan 12, 2015 | 12:31 PM
05PRMTX's Avatar
Mine is not a GPS unit. I plan on using my phone through the mirrorlink function. I would think on the windshield up by the review mirror would be the ideal place for signal though.
Old Jan 17, 2015 | 11:54 AM
SpeedyJoe's Avatar
.... help!
I just installed my Alpine with the Metra 99-5823CH kit and guess what, the Alpine does not work. The Metra kit works great.
Maybe it is because of my adapter, it's a mustang/iso adapter but not the PAC thing. The problem seems to be the missing acc signal and I have no idea how get it done!
Or do I have to get that PAC adapter. Even numeros wiring diagrams didn't help.
Any ideas?
by the way ... it's not the Alpine, had it checked at a local shop
Old Jan 18, 2015 | 01:20 AM
05PRMTX's Avatar
The pac adapter will give you an acc signal. You could also trying running a wire from the fuse box to pic up an acc signal.
Old Jan 18, 2015 | 02:56 AM
SpeedyJoe's Avatar
I have been thinking about the direkt wire but I guess that could drain the battery eventually. Actually I ordered the pac modul just to be safe!
Old Jan 30, 2015 | 11:32 PM
SpeedyJoe's Avatar
Finally got everything installed, the difference is like day and night! The sound of the alpine combined with the pioneer speakers is incredible. The radio reception is much better, I receive stations that I didn't get before and all stations are much clearer!
The added nav and bluetooth do the rest, just perfect. And the install with the maestro kit looks great, I'll try to shoot some pics later.
Old Jan 31, 2015 | 11:08 AM
califsp's Avatar
PICS!!!!!
Old Feb 8, 2015 | 08:27 AM
SpeedyJoe's Avatar
Here are some pics ...
Attached Thumbnails Base radio /double DIN conversion-alpine-maestro-01.jpg   Base radio /double DIN conversion-mic-install-02.jpg   Base radio /double DIN conversion-gps-antenna-03.jpg
Old Feb 8, 2015 | 08:39 AM
Onelildude's Avatar
I went with the iDatalink kit with a Kenwood DNX891 and it works well together. The biggest change is how good the speakers sound with the change of the head unit...i have JL's on the back dash, so i'm sure that helps too
Old Feb 8, 2015 | 09:42 AM
SpeedyJoe's Avatar
Well, I replaced all 4 speakers with pioneers. The install of the rear ones were a pain in the bud ... but it was worth it! The combo works just perfect, a shaker system can't possibly be better...
CNFLCTD
GT350
Aug 4, 2017 07:08 AM
oneeyedgiant
Nov 16, 2015 12:23 PM
Sep 30, 2015 07:02 PM
exgto
2012-2013 BOSS 302
Sep 28, 2015 07:39 PM
