Removing rear deck speakers
Old Feb 11, 2015 | 03:50 PM
ardeshna's Avatar
Question Removing rear deck speakers
Hi, I have a 2013 v6 base and I would like to replace the rear speakers. I did some search online but couldn't find any guide on how to remove the rear deck panel to swap the speakers.
Is anyone familiar with how to remove the rear speakers? Greatly appreciate your help. Thank you.
Old Feb 11, 2015 | 04:46 PM
Aren't they mounted from inside the trunk? A little nut driver action and they should drop right out
Old Feb 11, 2015 | 05:02 PM
ardeshna's Avatar
Nope they come out of top. we need to remove the top fabric/cloth that covers the speakers.
Old Feb 11, 2015 | 05:06 PM
Automatic 5.0's Avatar
Serious PITA!
Old Feb 11, 2015 | 05:15 PM
Joeywhat's Avatar
Remove the side panels enough to easily access the pins holding in the shelf, then remove those pins and pull out the shelf. It takes a little work to get it out since there's not a ton of room. You'll need to drop the rear seats down as well.
Old Feb 11, 2015 | 05:24 PM
ardeshna's Avatar
Thank you Automatic 5.0 that video explains everything in detail. I am going to install 4 Pioneer TS-A6885R and replace the head unit with Maestro MUS01 with RR and Kenwood DDX5901HD.
Old Feb 12, 2015 | 05:59 AM
Definitely replace the head unit. The speakers will barely make a difference but that stock head unit is low in power and fidelity. I will get around to replacing my stereo and speakers eventually. The only thing that has kept me from doing it already is the AC controls, buying the kit to replace the AC seems like such a waste.
Old Feb 12, 2015 | 08:44 AM
ardeshna's Avatar
True but I think the MUS01 kit allows you to configure some hard buttons on top of the head unit. I will be programming them for fan control and AC toggle.
Old Feb 12, 2015 | 11:38 AM
califsp's Avatar
I've done the rears without removing any interior panels and with out destroying the rear deck cover. The cover is held in place with 2 plastic push pins on each side right in front of where the seat belt is attached.
Old Feb 12, 2015 | 03:00 PM
Jazzman442's Avatar
Do you have a picture of that?
Old Feb 12, 2015 | 03:07 PM
ardeshna's Avatar
I had to remove door sills, side panels and then I had access to remove the deck. I wonder how you were able to accomplish this without removing anything.
Old Feb 12, 2015 | 03:46 PM
Joeywhat's Avatar
You can do it, but there's a lot of bending going on, and I personally don't care to risk breaking any of the interior panels to do it. The side panels aren't THAT hard to take off anyways, and they give you much more room to take out the pins holding the shelf in place (not to mention making it easier to remove the shelf).
Old Feb 12, 2015 | 09:34 PM
ardeshna's Avatar
I removed the side panels but I had to remove the door sills too and both of them broke, anyways I have ordered OEM replacement for door sills.
OEM speakers are out now, waiting for the new ones, cant wait to install them.
Old Feb 13, 2015 | 02:58 AM
Joeywhat's Avatar
The sills do not need to come out.
Old Feb 13, 2015 | 02:36 PM
califsp's Avatar
Anyone who is actually about to remove the factory rear speakers can call me I'm happy to walk you through it and save time, frustration and rattles! Just PM me.
Fords4Ever
Oct 30, 2015 09:07 PM
dblhelx
Oct 6, 2015 08:08 PM
seaclam
Sep 25, 2015 01:29 PM
Sep 8, 2015 10:45 AM
mustangsally_
05-09 Interior and Audio Mods
Sep 6, 2015 10:28 PM
