Adding rear AMP to Shaker 500 on 14 GT
Hello I have an old alpine amp I would like to add to the existing system and then add new rear speaker and a sub. Has anyone done this I would like to keep the original head unit I just want to make sure I get all frequencies to the rear. I would also keep the front configuration.
I just looked at the instructions and yep it does Thanks! Do you know if they pre run the power to the rear? I know the shaker 1000 has the sub in the back. other wise I will be running wires to the back
Ok I reread what you're trying to do, and I understand the "what" but I don't understand the "why." What are your goals? What are you trying to accomplish by just making the rears? It would make much more sense to amp the fronts....
Hello I have an old alpine 5 channels amp just sitting around that only used for a year. So I wanted to do the minimal changes $ since I am saving for a VMP STG2 SC that I am going to install in the fall. I just want to add subs and replace the rear deck speakers keeping the same head unit. This way I can get more full range sound from the rears. Since now they are pointless. I don't mind the fronts at least now. I would rather put my money into the motor. Maybe more stereo upgrades next year. Thanks again.
I always go back to the concert concept - well, smaller venues at least - the sound comes from in front of you, not behind you. I know you're still going to do what you want to do, but I hope you at least consider it. You have a good amp and a good start, spend $100 on a nice set of fronts, $100 on a box and $100 on a sub and you'd have a kickin system!
Thanks I will probably do the rear first and then depending on cost I will look at the fronts as well. When I first got the car I went for stereo estimates and all the places in Phoenix wanted around 4 - 5 k and I thought they were nuts. That is almost a superchager. LOL! I know it can get expensive. I will post pictures when I do it. I ordered some infinity subs and replacement infinity speakers for the rear. I am a woodworker so I will build a custom box for the subs and mount the amp to that. Thanks again
Trust me, audio is a disease, just like modding for hp lol. You're going to have better sounding rears, which will now sound better than your fronts - so then you're going to want your fronts to sound better too
So yeah, ask me any time if you need help or have questions. I have a pretty extensive build planned for my car when I get it.
Bummer I just read a review of this and it said it only passes mids and highs. That kind of defeats my purpose. I might be returning everything. Have you used this? I thought I saw somewhere that someone used the rear rca's to power a subwoofer. I saw on modded mustangs the radio only sends full range to the front which I think is stupid. I expected a full range to all four channels.
So, I've looked at that PAC module before, but I wasn't sure about it. Just to clarify, it gives an RCA a output to go into the processor right? I've got some engine noise on the speaker level inputs from my processor. There is no noise when I use the aux cable, so I was looking at a way to get a better input to the processor. Think this will do it?
The Pac works perfect. I did a quick test and hooked it up to the amp just on the floor and connected a speaker to it. It plays full range to it. Now I just have to install everything. It was kind of a pain getting the wires off the back of the radio it does not pull out all the way. But I would say get it, it works as advertised. I will post more pictures Sunday or next week. I got the PAC from Amazon
