Adding the OEM nav
Is there any possible way to enable Aux 1 2V on the radio when it is added? Im about to add a nav to a 2010 GT I just picked up but I couldnt reprogram my nav in the 2012 I had to buy one with it already activated. But it is getting harder to findout what options came on these wreckers.
Sooo. i found my self in a grey area for the main dash harness. my car is a 2013 gt premium with a 1/13 build date, there is an option for the harness around that time used from 6/12 to 1/13 then a harness used 1/13 to 6/14 im not sure which i need and im worried about getting the wrong one.
Just completed dash harness swap and first part of nav install. I am getting sound but it is very bassy. I still have to rewire the speakers just wanted to know if this is normal? I also have a after market back up camera with a yellow rca jack how do I connect that to the nav system? Since the camera gets power from back up lights can I just cut the rca jack and connect the wires to C210 pins 21 and 22? If I get them backwards will it harm anything?
HELP.. I was getting the clicking from the heating unit since I changed to dual. So I removed fuse 15 SJB started car waited 30 sec and reinstalled fuse now nav does not work or hvac. If I push the power button I see dashes for time in the upper right corner then it shuts off. DId I just ruin two days work? on a second note ForScan does not see the nav is this normal and so is 4Dtech the only way to add back up cam?
Fixed radio turn on this morning and no more clicking. I do have a extra Dual climate control top of housing if anyone is interested it has the motors but one I know clicks and the harness that had a frayed cable that I repaired let me know.
Need HELP in final stretch of Nav install I have created a harness from a rear amp to connect to front and then to speakers. My questions are how do I access c214 and C213 I see them in the diagram but C213 is between the metal in the passenger side and is C214 accessed from outside where the harness enter the door? Also my car originally had the shaker 500 with the two amps one on each side in the fronts. Does the mod bypass those two amps(I think so but it only has one set of front speaker leads for each side so the harness in the door should split to sub and speaker)?
