Adding the OEM nav
Finally have working A/C and navigation.
Also, discovered you do not need the newly priced gps splitter. It used to be $30, now it's $160. I found that as long as you don't mind having two antennas (one on the truck and one under the dash, out of sight) you can use your existing cable for your satellite radio and then buy the antenna that 4dtech.com has. I found the same one on eBay for $13.
I am indeed doing paddles and keyless.
The paddles are easy, but it is taking me some time to figure out the keyless.
I have been taking pics and will do a write up on both.
For the paddles, I used Mercedes AMG paddles and a control module made by LXCS. You can check the thread I have in the general 2010-2014 section.
I am using the EasyGo keyless system, but am using the idatalink instead of the keybox, and that is taking me some time to figure out.
GT227, I am glad that everything works for you now. I am sorry that you had such issues to deal with, but at least you have it now.
I have my new harness in now and the dualzone, and the dash is back in. Just redoing some of my custom wiring for pony lights, side mirror defrost and the select shift. I will then tackle the final 2 mods. Hoping to have my car running again by Friday.
Lexiion, since your car is also gutted, are you also putting in dualzone? I know that is the last thing to do, but just curious. You are also putting in the adjustable vie the console struts/shocks? What is involved in that?
The Shocks/Struts will be like the OE solution. The body harness has the connectors for the shocks, the VDM (Vehicle Dynamics Module) and i added the ride control switch to the dash. The light harness has the connectors for the Struts. As the PCM (MWJ3) understands the signals for changing the ride mode, it will be a flip of a button to get from normal to sport and back. Ecostang, who also has a 2014GT500 took me for a ride in his vehicle and i fell in love with the electronic adjustable dampers. So that one has priority over the dual zone. As I am still waiting for parts in order to put the dash back in, I still might decide on the dual zone.
LEXiiON
LEXiiON
LEXiiON
I forget where in the previous pages, but someone mentioned that sync has been slower to react after the swap. I too noticed that it takes longer for the woman to awaken when pushing the voice button or when I advance to the next song....not a big deal though.
I have not noticed Sync being slower myself.
My interior is back together (mostly). My paddle shifters are in and they are awesome.
Dual zone works, and my speakers and rear camera work again.
I promise to solder all my connections in the future to avoid doing a harness swap!
All functions for the climate should work except dual zone.
As for the steering wheel controls, which ones don't work? The only one I can think of that wouldn't work (if you didn't change the right side switches) is phone on the right side. But they should also work.
