Adding the OEM nav
Old May 15, 2015 | 04:56 PM
  #581
forceflow2's Avatar
Originally Posted by Marine8d
Odd question. I ordered the steering wheel controls (AR3Z9C888FA) and it doesn't have the "OK" button like my stock unit does. Is that to be expected????
Yeah, that's how it is. There is only the phone button now for it.
EDIT: Picture from my (dirty) car.
Old May 19, 2015 | 01:02 PM
  #582
Marine8d's Avatar
OMG!!! Please help... It's hot as hell and I can't figure out a way to switch out that last two top plugs of the climate harness... They are way hidden....
Old May 19, 2015 | 03:12 PM
  #583
Marine8d's Avatar
Thanks man, yeah after I put more thought into it I realized the "OK" button is your finger....
Old May 19, 2015 | 06:52 PM
  #584
forceflow2's Avatar
Not sure which ones you're talking about? None of them were really hidden, just had to pop the plastic tabs out to get the top wire out. The only hard ones were the blend motors, but if you unscrew them, they are a lot easier to do, although it is by no means necessary to do so. Do you have a picture of what you're looking at?
Old May 19, 2015 | 06:58 PM
  #585
Marine8d's Avatar
I'll see to it to take a picture tomorrow. FYI I don't have the dash pulled and the plugs seem to be behind the vent tubes right on the center
Old May 24, 2015 | 02:14 PM
  #586
trysavy's Avatar
Another success! I finished my install and everything works great. I recommend taking the dash out, it actually is pretty easy to take out.
I have some extra navigation parts that I want to sell. I have an extra ACM, screen, panel with buttons (no heated seats), and HVAC module (no heated seats). I tested it all during my install and everything works. I am unable to post these items in the for sale section for some reason but PM if you are interested or have questions.
Old May 24, 2015 | 09:52 PM
  #587
Marine8d's Avatar
Ok so... I'm an idiot...I should read more of the posts befor I ask questions the wire I was talking about wraps around to the driver side... AC fixed. Everything works and now just one final question. Can this be done for a "my ford touch" system what's so different about them that ford only integrated that into the 2015 mustang????
Old May 24, 2015 | 11:14 PM
  #588
forceflow2's Avatar
Doesn't really answer your question, but I had MFT on my 2012 Focus that Ford bought back because everything on it kept breaking and they couldn't fix it. MFT (possibly even more so after the 2.0 update) is an abomination that should never have seen the light of day. If you put it in your car, I recommend you set the car on fire and then throw the ashes in a volcano.
Old May 25, 2015 | 09:58 AM
  #589
trysavy's Avatar
I was able to post my extra navigation items in the for sale section. Please check them out if you are interested.
Old May 26, 2015 | 05:59 PM
  #590
trysavy's Avatar
Has anyone installed the navigation unit in a 2013-2014 Base model? Any idea if it would need the rear amp like the 2010-2012s? All it would really need extra to work is the satellite radio antenna, right?
If anyone has the wiring schematics for a 2013, could you please share with me? Thanks!
Old May 26, 2015 | 06:01 PM
  #591
p6cl's Avatar
Amp goes by driver front kick panel only rear amp is for shaker pro
Old May 26, 2015 | 06:16 PM
  #592
trysavy's Avatar
So all the 2013-2014 Mustangs have this amp? Even the base ones without the Shaker?
Old May 26, 2015 | 06:18 PM
  #593
p6cl's Avatar
No amp in base mustang had to add it. Bought on eBay
Old May 26, 2015 | 06:28 PM
  #594
trysavy's Avatar
Ok, thanks for your help!
Old May 28, 2015 | 06:18 PM
  #595
forceflow2's Avatar
I bought one of trysavy's extra HVAC modules and it arrived today. I put it in and my heated seats now work without issue. The unit I pulled out is labelled AR33-18C612-AF. No idea what Tasca actually sent me, but I know it doesn't have heated seats and it isn't what I ordered from them and what they wrote on the box.
On the plus side, everything is working like it should. Thanks again to everyone for their great support!
Old May 28, 2015 | 07:55 PM
  #596
trysavy's Avatar
You're welcome and if anyone is looking for the heated seats module make sure the last two digits start with 'B' so it should be a part number like CR33-18C612-BB for example.
Old Jul 12, 2015 | 12:34 PM
  #597
GT227's Avatar
Hi guys, just finished reading the 30 pages and it's been a while since the last post, but I'm ready to upgrade to the oem nav. Before I go to the online salvage guys, does anyone have any of the components or even a complete set that they decided not to go through with it?
I have a 2014 convertible with sync and shaker radio. From what I read, I shouldn't need a new amp. I'm not looking to convert to dual climate, but would like to find a package with rear view camera and heated seats.
Old Jul 18, 2015 | 05:18 PM
  #598
johntous's Avatar
I have a 2012 with Shaker 500 system do I still need the amp
Old Jul 18, 2015 | 10:31 PM
  #599
forceflow2's Avatar
2013+ are the ones that don't need it.
https://themustangsource.com/forums/...8/#post6518156
Old Jul 22, 2015 | 01:38 PM
  #600
GT227's Avatar
I'm just waiting on the harness and sensor from white bear lake. Just re-reading all the parts needed and may have overlooked this one...
climate system harness ($30) - AR3Z 18B574 B.
If I'm not converting to dual climate control, do I still need this? Will my climate be backwards without it?
