3M CF Vinyl interior wrapping
#41
Are you referring to the console pieces or the actual dash inserts? Console comes out easy, just open the arm rest and pull up on the cup holders. Around the radio is held in by a few screws. As for the actual dash pieces, I'm not sure they come off easily, if they even come off at all. Maybe someone else can chime in on that.
#42
Not sure if 10+s are the same but in 05-09s it seems like theyre snap-in and IIRC this was the case when I modded my headlight control but when trying to get the door handle trim out yesterday I had to stop because I started to mar the edges. I was using a thin screwdriver but could use something rubber/plastic but cant figure out what to use. Will try again tomorrow.
#43
#44
Originally Posted by slostang
Start with the cluster housing, just use your hands and pull on it and it will pop out, after that move UNDER the dash but dropping the glove box(2 push tags to get it over the dash material) and you will see 2(10mm?) bolts, unclip the airbag(also disconnect the battery). After you remove the airbag you can then remove the center vents with 3(?) 10mm bolts and the outter air vents will pull out. This is ALL off memory so forgive me if I am off a bit.
#45
hmm, I can't decide if I want to wrap my center piece. It has an odd stain in the finish that Ford refused to fix (and I'm sure had been there since I bought it, but alas).
I may give it a try and see.
#51
#52
#54
Finally got around to doing mine this past weekend. I painted the guage and vent bezels flat black also. I didn't much care for the chrome. I kinda f'ed up on the air bag cover, so I'll have to redo it pretty soon. I could'nt get the **** cover panel loose from those metal teeth, so I wrapped it while it was on the bag, and it was a *****. I covered the entire panel and was going to cut it down the middle to tuck it under. I cut a couple inches and it wasn't looking right, so I left the rest intact. the part that I cut has come untucked a bit, and I couldn't get the corners on the airbag panel to hold very good. there's not much flat surface area along the edges to get the vinyl tucked. Anyone have any advice on getting that panel done??? I think I have a plan, but I'm gonna wait til I'm sure before I go to the trouble of removing that thing again. I found out the top piece of my airbag panel is a little warped too, wtf? Right by the corner toward the center vents. I'm prob the only one that will ever notice; just weird though. Any way PICSwill get better ones at some point
Whatya think?
Whatya think?
#55
Whatya think?
Whatya think?
Sorry cant help with the vinyl.
#57
Originally Posted by perfect storm
For the passenger side airbag dash, did you guys just use 1 piece of vinyl? Or was a slit made for if ever the airbag deployed?
#60
I like this look, but not more than my 500's if I had a regular mustang, I would definitely cover it because it looks terrible IMO.
