2013 GT Sync Install
Old Sep 3, 2014 | 12:36 PM
Illi73's Avatar
Gt 5.0 Tms Member
Hello everybody,
Does anyone know if you can add a sync module to a factory 2013 GT system? I'd like to eventually get the Raxiom kit but it's pointless unless I have a Sync system.
Old Sep 3, 2014 | 12:39 PM
zeroaviation's Avatar
Yes you can add it. Search the forums it has been discussed numerous times.
Cheers,
-Matt
Old Sep 4, 2014 | 09:17 AM
AMDanBailer's Avatar
Former Vendor
Originally Posted by Illi73
Hello everybody, Does anyone know if you can add a sync module to a factory 2013 GT system? I'd like to eventually get the Raxiom kit but it's pointless unless I have a Sync system.
Yes. I think you should be able to add SYNC to your Mustang. I'm not sure what all goes into that process, though. Right now the Raxiom Navigation only works with SYNC Equipped Mustangs.
However, I know Raxiom is working hard to come out with a version for non-sync Mustangs! Stay tuned.. That should be an option really soon.
-Dan
Old Sep 5, 2014 | 10:52 AM
awoychosky123's Avatar
Hey m8 if you need help I installed sync on my mustang Base so I would love to help you out sync is great to have even if your going to upgrade the radio head.
Old Sep 8, 2014 | 09:33 AM
Illi73's Avatar
Gt 5.0 Tms Member
Thanks awoychosky123, any information you have is greatly appreciated.
Old Sep 8, 2014 | 10:55 AM
First things first read through this thread in your free time but I will highlight the important parts. You will need male and female pins a 2009 sync kit a auto dimming mirror with mic and a 2012 sync module take off (Have some if you need them) you also will need a premium radio head (You can find all this on ebay) you will need to do some wiring. Disclaimer (You might get a 911 assist error like I have if this occurs you most like need to get your airbag module reprogrammed to a premium model to fix this or a model with sync.
Old Sep 12, 2014 | 02:53 PM
RobDis's Avatar
If you decide to do this and you need the parts I should have all the parts you need minus the radio bezel. Just PM me here if you are interested and want to take on this mod.
Old Jun 10, 2015 | 02:52 PM
crgwebb1's Avatar
I am excited to hear about your Sync installation.
I have done similar with a 2013 base Mustang. I put a 2013 Sync module from another car with the 2009 Sync Kit.
Bluetooth, USB and most Sync functions work fine but I cannot get the microphone that came with the Sync kit to work. I can push the HMI that came with the sync kit and it verbally responds but does not seem to hear anything from the microphone.
Just wondering if you had any troubles using the 2009 Sync Kit microphone or if I need to get a 2013 Sync Microphone mirror or something else for it to work?
I also upgraded to a 2013 Shaker head unit which gave me possible satellite radio (if I can get an antenna for it) but not much else really changed with this head unit.
I also have the 911 Assist Error that wants me to take to the dealer. Did you ever come up with a solution for that? My car has had the driver side air bag recalled just last week and will have to go in for this but I wonder if I can get them to program it to my Sync donor car VIN#.
Let me know what you ended up doing with your car?
Old Jun 10, 2015 | 06:24 PM
crazietj's Avatar
The wiring that comes with 09 kit needs to be repinned for the mic for 13s. I don't remember which ones it was, but in my post there are wiring diagrams for the 13s and talks about it in that post.
https://themustangsource.com/forums/f803/2010-base-sync-retrofit-530259/
If you are using the mirror with the mic in it. Make sure you have the harness going to the mirror, and it has to have power to the mirror as well.
Old Jun 10, 2015 | 06:25 PM
crazietj's Avatar
I do have a 13 sync module, and a 13 AMC as well if anyone is interested.
Old Jun 13, 2015 | 11:36 PM
fivepoint00's Avatar
How much did everything cost to have sync?
Old Jun 14, 2015 | 06:30 PM
crazietj's Avatar
Depends.
What I paid.
Gt 500 steering wheel, $160
2009 sync add on kit. EBay $50
2013 acm. EBay $40
2012 sync module. EBay $40
2012 mirror with sync mic. EBay $40
2012 mirror harness. Tasca $30
Old Jul 6, 2015 | 05:45 PM
crgwebb1's Avatar
I previously reported a problem with the 2009 Sync add on kit in my 2013 Mustang. The microphone was not working but I just discovered how that the red wire on the 2009 Sync add on kit is necessary to get 12v power for the add on kit microphone to work on my 2013 Mustang. With 12v power on the red wire, the 2009 Sync kit microphone works fine.
With the add on kit and 2013 Sync module from another car, I now have full voice controls and Wired Handset Button control over the Sync system.
I have the mirror microphone on order but I am not sure how to wire it up so at least this will work for now.
My next projects include:
Adding the Microphone Mirror
Pinning for the Sync steering wheel controls
Finding out how to eliminate the Assist 911 Error
Ayowchosky123 said this could be fixed by airbag re-programming but I heard from Ford Sync hotline that this could be caused by the Assist 911 system getting deleted during update and a shop in Arizona that specializes in Sync programming said that it was due to a missing GPS module. They said that they GPS module is used to identify where the car is during an accident and the error will be present until a GPS module is connected. Was Ayowchoski123 or anyone able actually to fix the Assist 911 Error? I appreciate any guidance on this so I do not have to buy any more parts or pay for labor at the dealer than I dont actually need to fix this issue.
Adding a Satellite antenna to the Shaker radio for satellite
Can anyone confirm the 2013 P/N for the mirror harness
Old Nov 29, 2017 | 09:32 PM
crgwebb1's Avatar
Awoychoski123, can you advise how to find a dealer that will reprogram the Restraint Control Module to a premium. My dealer claims they can't do this.
Old Oct 20, 2019 | 05:07 PM
crgwebb1's Avatar
Reprogram of restaint control module to a premium 2013 model
Has anyone found out how to get a dealer to reprogram the restraint control module to a premium?
Old Jan 4, 2020 | 07:23 PM
Jose Dan's Avatar
I have a 2013 base mustang and I’m getting the sync module of a 2013 gt mustang can take the wiring and module from it and out it in mine
junkman9096
'10-14 Interior and Audio
May 12, 2016 12:43 AM
Mustang259
74
Mar 25, 2016 04:27 PM
SMBJoshy
Aug 16, 2015 02:48 PM
oldnjguy
Jul 19, 2015 07:20 AM
