v6 GT Style fogs install
Old Sep 28, 2014 | 05:49 PM
Qsmith23's Avatar
Okay I have a 2014 V6 and I purchased a stock GT grille and fog lights to put on my car does anyone have any pictures or advice as to how the fogs actually mount on To the grille ??
Old Sep 29, 2014 | 06:48 AM
Dfink114's Avatar
You can check out my post here: https://themustangsource.com/forums/...2013-a-516464/
Old Sep 29, 2014 | 09:02 AM
Qsmith23's Avatar
Originally Posted by Dfink114
Okay so how did you attach the fog lights to your grille? I might be missing a part I don't know yet
Old Sep 30, 2014 | 06:21 AM
Dfink114's Avatar
I believe the lights screw into the grille surround. You need the GT Grille Surround, the V6 one doesn't work.
Old Sep 30, 2014 | 09:20 AM
Joeywhat's Avatar
When you remove the bumper, look at the top grille, where the lights will go. There is a bracket of sorts that the grille itself attaches to, that is what the lights will mount to. When you remove the grille from the bumper that whole assembly comes out first, then you remove the grille from the bracket/surround and mount the lights and new grille.
Old Oct 2, 2014 | 04:04 AM
mnoury's Avatar
File Type: pdf
Old Oct 2, 2014 | 12:21 PM
Qsmith23's Avatar
dang i think i got the wrong grille do any of you know where i can get the right one?
Old Oct 2, 2014 | 04:44 PM
Joeywhat's Avatar
Your V6 should already have everything you need.
Old Oct 3, 2014 | 06:54 AM
Starkey Products's Avatar
I was going to post the instruction manual after seeing this, but looks like Noury beat me to it.
What parts do you have right now? List the part numbers (if possible) and I'll tell you if you are missing something. We sell a lot of complete kits and I've installed these grilles a bunch of times.
Jason
Old Oct 4, 2014 | 10:29 AM
mnoury's Avatar
Jason
Starkey's Kit/Manual is the best
Old Oct 9, 2014 | 12:35 PM
Qsmith23's Avatar
these are the two items ive purchased. i dont have the item numbers
Grille: http://www.ebay.com/itm/181406899690?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITLights: http://www.ebay.com/itm/171434394551?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Oct 9, 2014 | 01:17 PM
Joeywhat's Avatar
Old Oct 10, 2014 | 06:06 AM
It looks like you have the correct parts! That Upper grille/surround can be installed into your bumper no problem. It will replace the factory chrome surround that is on your car now. Lamps are good as well. Just follow the instructions Noury posted - they pretty much walk you through that part of the install.
The only other things you'll need are a GT lower grille to match and the correct wiring.
The wiring you need will depend on if your car came equipped with factory fog lamps or not. If you have a base with no fog lights, you'll need a full wiring harness. You can read more about that product here:
http://www.starkey-products.com/must...-boss-302-2013
If your car came with factory lower valance fog lights, the wiring is much simpler and can be found here:
http://www.starkey-products.com/must...11-led-GT-2013
Our harnesses' are pricey, but they make the install a breeze and are manufactured right here Florida. If you need something on the cheaper side there are some more generic options on eBay. The only downside with those is they are tougher to wire, aren't designed to work with the OEM headlight/ foglight switch, and don't shut off automatically when the car is turned off.
Let me know if you have any questions!
Jason
Old Oct 10, 2014 | 08:28 AM
Qsmith23's Avatar
Thank you very much jason! I guess Ill just have to take the bumper off to see what im working with.
Old Oct 10, 2014 | 08:34 AM
Qsmith23's Avatar
So on the wiring harness do you need the H11 lower valence option or the H10 roush??
Old Oct 10, 2014 | 09:35 AM
You'll actually need to pick the LED connector option which adds the 3513 to the order. These are adapters that convert from H11 (which is the normal factory option on the V6) to the LED connector used on the GT fog lights.
Let me know if you have any other questions!
Old Oct 10, 2014 | 12:28 PM
Joeywhat's Avatar
Also make sure to get the mounting hardware from Starkey. You'll need the six screws to mount the lights, unless it came with them already.
Old Oct 10, 2014 | 05:14 PM
Qsmith23's Avatar
do you have a link for the mounting hardware?
Old Oct 16, 2014 | 08:59 PM
Qsmith23's Avatar
Hey just placed an order with you guys for the harness and led conversion kit. Do you send out a receipt via email? Because I haven't received mine.
Old Oct 17, 2014 | 07:22 AM
Good morning,
I see your order, thank you. I will make sure they process and ship today. Not sure why you didn't get the order notification. I am going to have them email you directly with a receipt/ tracking number. If you don't get it in the next few hours let me know!
Take care,
Jason
