v6 GT Style fogs install
Okay I have a 2014 V6 and I purchased a stock GT grille and fog lights to put on my car does anyone have any pictures or advice as to how the fogs actually mount on To the grille ??
You can check out my post here: https://themustangsource.com/forums/...2013-a-516464/
Originally Posted by Dfink114
(Post 6855288)
Originally Posted by Qsmith23
(Post 6855347)
Okay so how did you attach the fog lights to your grille? I might be missing a part I don't know yet
When you remove the bumper, look at the top grille, where the lights will go. There is a bracket of sorts that the grille itself attaches to, that is what the lights will mount to. When you remove the grille from the bumper that whole assembly comes out first, then you remove the grille from the bracket/surround and mount the lights and new grille.
1 Attachment(s)
:nice::nice:
dang i think i got the wrong grille do any of you know where i can get the right one?
Your V6 should already have everything you need.
I was going to post the instruction manual after seeing this, but looks like Noury beat me to it.
What parts do you have right now? List the part numbers (if possible) and I'll tell you if you are missing something. We sell a lot of complete kits and I've installed these grilles a bunch of times. Jason |
Originally Posted by Starkey Products
(Post 6856863)
these are the two items ive purchased. i dont have the item numbers
Grille: http://www.ebay.com/itm/181406899690?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AITLights: http://www.ebay.com/itm/171434394551?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT |
Originally Posted by Joeywhat
(Post 6855712)
It looks like you have the correct parts! That Upper grille/surround can be installed into your bumper no problem. It will replace the factory chrome surround that is on your car now. Lamps are good as well. Just follow the instructions Noury posted - they pretty much walk you through that part of the install.
The only other things you'll need are a GT lower grille to match and the correct wiring. The wiring you need will depend on if your car came equipped with factory fog lamps or not. If you have a base with no fog lights, you'll need a full wiring harness. You can read more about that product here: http://www.starkey-products.com/must...-boss-302-2013 If your car came with factory lower valance fog lights, the wiring is much simpler and can be found here: http://www.starkey-products.com/must...11-led-GT-2013 Our harnesses' are pricey, but they make the install a breeze and are manufactured right here Florida. If you need something on the cheaper side there are some more generic options on eBay. The only downside with those is they are tougher to wire, aren't designed to work with the OEM headlight/ foglight switch, and don't shut off automatically when the car is turned off. Let me know if you have any questions! Jason |
Thank you very much jason! I guess Ill just have to take the bumper off to see what im working with.
So on the wiring harness do you need the H11 lower valence option or the H10 roush??
(Post 6858666)
You'll actually need to pick the LED connector option which adds the 3513 to the order. These are adapters that convert from H11 (which is the normal factory option on the V6) to the LED connector used on the GT fog lights. Let me know if you have any other questions! |
Also make sure to get the mounting hardware from Starkey. You'll need the six screws to mount the lights, unless it came with them already.
do you have a link for the mounting hardware?
(Post 6858679)
(Post 6860661)
Hey just placed an order with you guys for the harness and led conversion kit. Do you send out a receipt via email? Because I haven't received mine.
I see your order, thank you. I will make sure they process and ship today. Not sure why you didn't get the order notification. I am going to have them email you directly with a receipt/ tracking number. If you don't get it in the next few hours let me know! Take care, Jason |
