Switching the rear valance
Old Apr 2, 2010 | 12:04 PM
2010MustangGT's Avatar
I know some of you have done it, but the posts are few and far in between...
How hard was the install? Any pictures along the way? Advice?
Anyone go Roush as opposed to GT500 valance?
And now even the 2011 v6's can chose to swap as well...
Thanks!
Old Apr 2, 2010 | 12:11 PM
stangfoeva's Avatar
MOTM Committee Member
Thanks!
dmhines did it. He said all you need is a screwdriver IIRC
Old Apr 2, 2010 | 12:20 PM
dmhines's Avatar
It's pretty simple ... I didn't take pictures:
1) Remove 3 screws inside each wheel well.
2) Remove all the plastic rivets attaching valance underneath car (6 I think)
3) Open Trunk and remove the inner rear panel to expose wiring harness for directionals and license plate light
4) Disconnect the harness and push rubber grommet through the body
5) Begin pulling the rear bumper cover and it will start POPPING off the body - have a large blanket on ground to lay it on so you don't scratch the paint
6) The Valance is held to the bumper cover with screws + plastic rivets + slotted tabs
7) Remove lower valance ... it will be obvious how to do it .. although a bit tricky.
Reverse procedures to put it back together.
I installed the GT500 rear valance .. know also known as the 2011 GT/CS rear valance .. which works out good since I'll be ordering the GT/CS front end parts once they become available!
Old Apr 2, 2010 | 01:35 PM
08Shelby's Avatar
I didn't know where were rivets... sucks, but ok. Question, did you re-rivet the new valance?
Thanks!
Old Apr 2, 2010 | 01:39 PM
dmhines's Avatar
Thanks!
They are reusable plastic fasteners ... look like rivets ... you reuse all the parts.
Old Apr 2, 2010 | 01:43 PM
08Shelby's Avatar
Oh! Ok! Rivets are completely different, heh. I was thinking this was going to be a little harder than I originally planned, heh.
Old Apr 11, 2010 | 01:24 AM
Overboost's Avatar
Here's the link for the Roush instructions, which work for the GT500, Steeda, etc.
http://store.roushperformance.com/im...009_manual.pdf
Their site says 3 hours and intermediate tools, but I'm sure it's less.
Old May 6, 2010 | 02:09 PM
JScottGT's Avatar
I will be doing this on my '10 V6 for duals. I will try to take pictures and document the process.
Old May 8, 2010 | 06:12 AM
Stangpilot007's Avatar
Steeda has a rear valence coming out soon too, check out the 2010 Q350. It's very similar to the GT500, but slightly more aggressive. I'm waiting for that one.
Old May 8, 2010 | 06:58 AM
Overboost's Avatar
From the pics I've seen, it looks like a 3DCarbon product. I do like the styling, but the price might be the reason I skip it. I'm all about style, but I'm not about to pay $3-400 for something because it's mildly different. The GT500 valence can be had for $130, and that's a great deal IMO.
Old May 8, 2010 | 07:11 AM
Yeah if it's that much more I will likely skip it as well.
Old May 8, 2010 | 07:17 AM
Overboost's Avatar
I was looking at the Steeda front bumper from the Q350 and they've said it will be $649-699. I can buy the CS front splitter and brake cooling kit for that much, and not have to worry about paint either. I'll reserve final judgment til all the facts are out, but from what I've seen, it might be a costly upgrade if you go that route for front/rear fascias.
Old May 8, 2010 | 09:15 AM
GJM20115.0's Avatar
dmhines
I'm going to go with a CS front on my 11 GT (on order).
Says on the Ford ***. site you also need a GT adapter for the grill Is this just the grill surround that I assume one could re-use? --No part # listed for it.
Old May 8, 2010 | 12:01 PM
stangfoeva's Avatar
Same here Overboost. Gus did say he'd give a discount to TMS members, but no doubt the Steeda front fascia will be more expensive than the CS plus you have to pain the Steeda fascia...
Old May 8, 2010 | 12:40 PM
Overboost's Avatar
Yeah, I know we've talked about it before, but I'm not keen on spending close to a grand for a bumper. Especially when there's a cheaper solution for about half the price. I do like the Steeda design, but the Ford accessory pieces are looking more and more appealing as more things come out.
Old May 12, 2010 | 11:11 PM
Just for reference, one of the few websites I even see the GT500 rear valance listed is on Stangmods. For 169.95
But use "stangmods" as a coupon code and you'll save $8.50 for $161.45. Not too bad...
http://www.stangmods.com/2010-GT500-...rt-p/01315.htm
Old May 12, 2010 | 11:19 PM
Ltngdrvr's Avatar
Check the ford parts websites, I had found the GT500 valance as low as $130.
Old May 12, 2010 | 11:45 PM
Ford accessories is selling it for $185.17...
Ebay I assume for the $130's?
Old May 12, 2010 | 11:54 PM
stangfoeva's Avatar
KC sells them here for $130
kponypower
Jun 17, 2020 07:17 AM
Evil_Capri
Sep 25, 2015 12:56 PM
Evil_Capri
Sep 11, 2015 08:39 AM
Sep 10, 2015 12:44 PM
