Roush side splitters
Old Aug 17, 2012 | 03:29 PM
Getportfolio's Avatar
My Roush splitters came in the mail today along with some other goodies. For those who have installed the splitters:
Any tips? Why are some installed splitters I've seen really wavy? How long before the young ones knock them off getting in and out of the backseat? The splitters are more flimsy than I anticipated.
Attached Thumbnails Roush side splitters-image-3450693756.jpg   Roush side splitters-image-1106684953.jpg
Old Aug 17, 2012 | 04:18 PM
Onelildude's Avatar
The only tip i can give is to be careful taking the plastic pins out of the stop piece...they break pretty easy
Old Aug 17, 2012 | 04:39 PM
2012GTCS's Avatar
Theres factory pieces In front of the rear tires attached to the stock side skirts. I removed them or else the splitters wouldn't sit flush in the rear. They are almost like a hidden mudflap. I just removed them. The directions didn't mention them.
Other then that, straightforward. Just clean with alcohol real good first
Old Aug 17, 2012 | 08:05 PM
Can the Splitters be installed with the flaps or is too tight? I really like the flaps. They keep the splash down.
Old Aug 17, 2012 | 08:19 PM
wannabe's Avatar
I put mine in with those flaps there a few weeks ago. Wasn't happy with the way it went together.... but you have to look at it from very low (like on the ground) to see where it's not right. But this morning I noticed the passenger side was all out from under everything and 'crooked'. I used some 3M tape to try get it to stay back where it belongs, but that's not holding very well. Never occurred to just take them off.
As to the 'flimsy'... that was my immediate thought as well. But the tape and 10 push thingies hold it up there pretty good. I'll still kick it getting in and out occasionally, though.
Old Aug 17, 2012 | 10:40 PM
Thanks guys. That is why I love this forum. I had a hunch about one of the flaps because it is a little warped. I thought it may create some distortion to the material when installed. Thanks again! I'm taking those flaps off.
Old Aug 17, 2012 | 10:44 PM
gregtommy's Avatar
they do offer places to drill holes in the rocker panel which i recommend using. 3 holes in each piece and push additional pins through them keep them tight to the rocker panel
Old Aug 18, 2012 | 06:53 AM
MyStang2010GB's Avatar
^^^ This ^^^
Old Aug 18, 2012 | 10:41 AM
GtStang4's Avatar
Installed mine without removing the flaps, have been fine so far. I did drill the extra holes for the additional push pins.
Old Aug 18, 2012 | 12:10 PM
Do those flaps really even do anything? I could see if the were on the rear bumper run they would prevent splash. Now that I think about it, I guess they only prevent splash on the under carriage? Pics welcome btw.
Old Aug 18, 2012 | 12:57 PM
TheDivaDanielle's Avatar
nice ladybug.
Old Aug 18, 2012 | 01:38 PM
Karnage541's Avatar
I left the flaps on. I just cut them in a way that they wouldn't put force on the Roush splitters and everything looks fine. And yes, they keep the water from splashing all over the Roush spliters. So it keeps them a bit cleaner looking then if you would just remove them. I drive through some nasty stuff so it was important to keep them on.
Old Aug 18, 2012 | 03:15 PM
nice ladybug.
You noticed!
Old Aug 18, 2012 | 05:42 PM
Any detailed pics?
Old Aug 18, 2012 | 06:43 PM
Tight Lines's Avatar
Here's how I cut the rears. I used a Dremel cutting tool.
Old Aug 18, 2012 | 07:15 PM
Thanks that helps a lot. I appreciate it.
Old Aug 18, 2012 | 09:05 PM
No problem. Glad I could help, good luck with the install. Pretty straight forward.
Old Aug 20, 2012 | 10:47 AM
2012GTCS's Avatar
I removed those darn things. I could see what their purpose was Under the car lol. Plus it's a weight saving mod. LOL
Old Aug 20, 2012 | 02:27 PM
I tried to pull mine off before instal. Those things are on tight!
Old Aug 20, 2012 | 06:56 PM
2012GTCS's Avatar
Same here. But then realized theres a screw
