Powder coating exhaust tips?
Old Jul 8, 2012 | 03:14 PM
mikeyt03's Avatar
Has anyone powder coating their exhaust tips? I want to get all if the chrome off my car, and I was thinking about this. Do you think the color will hold up? Will I have to cut off the tips to do this? Also, one tip hangs lower. Is there a quick fix to this without bending the hanger?
Old Jul 8, 2012 | 03:17 PM
AlsCobra's Avatar
A Man Just Needs Some....
Haven't done it but I'm planning on it eventually. It will hold up. The tips don't get enough to bake it off.
Old Jul 8, 2012 | 03:24 PM
what Al said I don't think there's any packing inside these mufflers so I would just have the whole thing powder coated.
Old Jul 8, 2012 | 03:43 PM
mikeyt03's Avatar
Are you guys thinking gloss or flat?
Old Jul 8, 2012 | 03:49 PM
AlsCobra's Avatar
Undecided. Haven't seen many black tips at all. Will never hurt to go gloss.
Old Jul 8, 2012 | 08:03 PM
mikeyt03's Avatar
Yeah I Can't find many pics.
Old Jul 10, 2012 | 07:58 AM
2012GTCS's Avatar
PlastiDip them!!! I did a test run on my Roush tips that do get pretty hot. I romped on the car for a while to get them real hot. Had it on for weeks, no change in looks or melting. Your good to go.
Plus with the amount of black carbon that comes out of our cars it's worth it for ease of cleaning or not cleaning lol.
I hope everyone's car has a lot like mine anyway. Usually a day after cleaning they're all black on the lower half
Old Jul 10, 2012 | 11:38 AM
mikeyt03's Avatar
Wow plasti dip works? Do you have pics?
Old Jul 10, 2012 | 11:48 AM
youngstang90's Avatar
Yeah, I'd like to see this too!
Old Jul 12, 2012 | 04:00 PM
Scuba-Matt's Avatar
You'll have to etch the chrome with acid or the powder coat won't stick. I'm not a fan of plasti dip, it looks like truck bed liner spray or body undercoating.
Old Jul 13, 2012 | 07:09 PM
Tron84's Avatar
If done right it looks very nice and smooth, nothing like the rough, lumpy look of bed liner
Old Jul 13, 2012 | 09:15 PM
slostang's Avatar
I had mine done on my charger and they end up looking "dull" anyway, I plan on doing a satin/semi not a full gloss on the 5.0.
Old Jul 15, 2012 | 01:27 PM
linelock's Avatar
You can adjust the tip pretty easily by loosening the joint at the axle back connection then hold tip where you want it while you tighten the joint. I used some spacers between the tip and the lower facia to help keep the tip where I wanted it while tightening.
I think powder coated tips would look awesome
Old Jul 16, 2012 | 07:19 AM
Scuba-Matt's Avatar
Those came out nice. Not like the plasti dip stuff I see on cars around here.
Old Jul 16, 2012 | 07:56 AM
CCTking's Avatar
Well that is plasti dip on his rims. If you do the prep work right and take your time with the coats it can come out looking very nice. If not, then yea it ends up lookin like bed liner
Old Jul 23, 2012 | 07:23 AM
2012GTCS's Avatar
I said the same thing as Matt. My faux cap came out bumpy. But damm your wheels came out awesome! What was your trick to getting it smooth and even like that??
Old Jul 23, 2012 | 07:39 AM
The biggest thing is keeping a good distance from the surface you're spraying. I found that 6"-8" from the surface works great. And keep a consistent speed going across.
This is all plasti-dip....
Old Jul 23, 2012 | 08:22 AM
Tron84's Avatar
I think another thing is to get the coats on thick enough, if you go light with the coats it gets a rough look.
Take a piece if cardboard and practice, it shouldn't take long to get it down right
Old Jul 24, 2012 | 11:11 AM
2012GTCS's Avatar
I did like 3 light coats, the first being super light. Then by the 4th and 5th I was getting so impatient I started really laying it on. Then when I took the tape off it peeled up in a few spots on the edges of the faux cap. I had it taped off right under the badge. I've seen people make a square around it??? Then I guess razor blade the edges? Help!!!
Old Jul 24, 2012 | 02:45 PM
No...when you peel with the square, it does a clean line when it hits the separate surface of the cap. It's really cool watching.
The biggest thing is patience with this stuff. The thing I keep telling myself when I'm spraying, is "THIS IS SOO MUCH CHEAPER THAN DOING ANYTHING ELSE, MAJE IT COUNT!"
Practice, and it'll come out perfect every time. I'd it doesn't, figure out what you did wrong, peel up the mess, and spray again.
Mar 30, 2021 09:29 AM
Cobiecane
Oct 23, 2015 08:44 AM
Sep 24, 2015 08:15 PM
