OEM 18x8 wheels vs OEM 19X9
Old Nov 9, 2012 | 10:48 PM
Will3212's Avatar
Right now I have the factory stock 18x8 wheels with the stock 235/50 18 tires. I want to purchase some used 19x9 oem wheels. I don't have the brembo package. My car is not lowered, do you think this is worth getting? I'm doing it just for looks, I actually heard it hurts performance a bit cause of weight?
Old Nov 9, 2012 | 11:02 PM
Planeswalker's Avatar
The 19s are heavier, tires are more expensive, and it's harder to find tires to fit 19s. You could always lower your car if it's the gap you dislike.
Old Nov 10, 2012 | 01:17 AM
Will3212's Avatar
18" wheels look kind of small for this car, 18" wheels on lets say a 370z is fine cause the Z is a small car, but the Mustang is bigger.
Old Nov 10, 2012 | 04:31 AM
Getportfolio's Avatar
Go 20 or leave it alone. Not worth it.
Old Nov 10, 2012 | 06:13 AM
MRGTX's Avatar
19s fit the proportions of the car perfectly, IMO. 20s are over the line.
Old Nov 10, 2012 | 07:27 AM
rm2092's Avatar
I went from the stock Prem 19" wheels to SVT 18" and have no regrets, good luck finding tires on the shelf for 19's.
Old Nov 10, 2012 | 07:52 AM
Pilks's Avatar
True, and if i remember correctly, you can fit a 275 on a 19x9. Get some better traction, have the ability to rotate tires, and have a decent stance. Can someone confirm on all that?
Old Nov 10, 2012 | 08:07 AM
I said this because its hard to find tires for 19s. The 20s are a lot easier overall. I personally have never owned a stang with larger wheels than 18x10. I like that size.
Old Nov 10, 2012 | 08:57 AM
TheDivaDanielle's Avatar
go with the brembo 19's.. while you're at it, buy mine. :-) (need to get mine sold)
Old Nov 10, 2012 | 09:45 AM
Yes you can. 275s are as wide as you can safely go on 9" wide wheels.
Old Nov 10, 2012 | 02:58 PM
Gtstyles2's Avatar
I'd say it is, personally I have staggered 20s but have u considered the black Brembo wheels? They would transform your car completely paired with lowering springs
Old Nov 12, 2012 | 01:55 AM
etc1006's Avatar
I got a set of the 19" for mine. It definety looked better! I just pulled them off today for winter and put the 18" back on. I got a set of Brembo rims this week cheap with sensors with some mild curb rash (just the finish) that I'm going to redo in matte charcoal for next winter. I'm doing RTR wheels for summer next year, and putting Brembo brakes on my 10'.
Old Nov 19, 2012 | 08:39 AM
Xtian85's Avatar
I just finished putting the 19's on mine. I shopped around the BEST I could and if I had to do it again I would have went for 20's the wheel wells on this car are humongous. I spent:
Brembo wheels-550
Tires-830 ( -80 Rebate) 750.00
Install-135
1435.00 You can save up a little more and go aftermarket.
Fred_Garvin
Sep 17, 2015 04:10 PM
