MMD Hood struts
Hey all, I just installed these mmd hood struts and I really like what they bring to the car but I had a question that is kind of a worry for me at the moment. The upper bracket that's mounted to the hood has a very small gap towards the side without the bolts that I've got a pic of below. Anyhow this gap leaves for some hood flex when you go to shut it until the hood contacts the bracket. So I'm wondering if anyone else with these has seen this or if there is a reason for this and or if it could be harmful. If anyone could shed some light on this I would appreciate it. On a side note these are on sale on AM right now making for a great deal. Talking about AM, Dan maybe you have an answer or connections to mmd?
I looked at all available struts, then chose the "Redline Plus" setup. I didn't like large brackets or mounting struts to the hood hinge points. The Redlines bolt to the fender attachment flanges and an open hole in the hood (well above the hinges). The Redlines are longer, but were a piece of cake to install. Matter of fact, one strut holds the hood up, so I can confirm they are hell for stout.
hadtohaveit'13,
There is normally a small gap between the bracket and hood with the MMD hood struts. Since the hood hinges stick out past the hood slightly, it forces a small gap when mounting the straight MMD brackets.
I haven't seen any issues with having a small gap here. As long as the mounted bolts are secure, you shouldn't have have any worries. Tons of other forum members are running these hood struts with no issues, plus we've equipped all of our AM Mustangs with the same setup!
Hope this helps ease your mind. Let me know if you have any other questions!
Shane
Shane
When I close my hood the brackets move slightly inboard. The brackets are labeled and are on the right sides. A guy at a car meet has the same issue. You make them straight and tighten back down then when you close it they move again. Crap.
Yeah that's exactly what I'm experiencing
Hood flex? You're lifting the hood arms and not the hood. The load is transferred from the strut to the strut mount to the hood lift arms.
I will go look at mine again; but I observed zero flex when using these post-installation.
Worth looking into.
Worth looking into.
The hood flex happens when closing the hood, pullin down on it
Those are nice too.
I saw some flex between the hood and bracket as a result of the load being placed on the hood countering the force of the struts when lowering.
I am going to try a small patch of dense foam to take up the space and provide some support to the hood as it is closed. It's minor, but flex on metal can equate to paint cracks later.
Yeah it's pretty minor flex but nonetheless it shouldn't be happening, and it scares me. I've thought about putting something in that gap as well to help out with it but I may just take these things off
A very light movement of the bracket is normal for these hood struts. The hood will experience a small flex too. We haven't found or experienced any issues with this, as long as the brackets are installed properly. Make sure to follow the installation instructions about you'll be set!
Shane
Shane
Shane
9/16/15 07:44 PM
